Join the SatelliteGuys Folding@Home Team!
I have taken a break for a few weeks because I decided to overclock my 970s for extra gaming performance. Because I was trying to lock down the best overclock I could get without causing instability or heat issues I disabled folding. I do plan to get back into it at some point though.
Edit: For now I may just enable it on my i5 at the office. It will likely only be able to get around 2-3K per day during work hours though so I'm not sure if it's even worth messing with.
I am down in my Folding Lair and I tried something I should have done ages ago: I moved the GTX 750 Ti bus-powered GPU into my Mac Pro. It works better there than in the HP xw8200!
As you can see, I left some breathing room between the cards. With the current WUs, FAH Control is showing 288K PPD just for my Mac Pro!
Without a valid GPU in it, the HP is showing under 1K PPD and as soon as this WU is complete, I'm officially retiring the xw8200 from service.
I'm still trying to figure out the DIMM situation on the new Dell. I've installed the new GTX 970 AMP! Omega card (fit like a dream, lots of room for an additional GPU!) but even though I moved the DIMMs into different slots, POST says DIMMs 3 or 4 have single-bit error detected. If it's like the PowerEdge servers at work, I need to run Dell diagnostics to clear it out. After over an hour of the built-in Pre-boot Memory tests, no errors have occurred.
Here are some pics of The Beast:
And here's the Foxbat Folding Liar:
Edit: Update after it's been running for a couple of hours: I think I can now give Scorpion.sting a run for #1. Let's give it a week and we'll see. FAH Control shows >450K PPD for all my Folders. :D
Bring it Roland :glasses
Reactions: Foxbat
Put those idle CPU & GPU cycles to work.
Got it fired up on 2 i5s at work and running on both 970s at home again. For now I am running it with my GPU overclocks disabled to get a base line for temperatures with sustained folding. Folding always pushes my temps up higher than I see in any of my games so I'm hesitant to try it with the overclocks active until I have temperature numbers to compare it with.
Reactions: Voyager6
Friendly? Of course. :fencing Tommy guns at ten paces?
However, for the experts out there, tonight I just purchased a second 970 $295 with promo code at Frys (after rebate). I can't install it until my current work unit ends om a couple of hours - I'm not throwing 134K away. For folding, is there any advantage to an SLI setup? I've heard it's a pain on Win 10.
No to SLI, not needed for folding.
I have read that the client can give you fits if you have it in SLI.
My 970s are SLI because that's the only way to take advantage of both of them for gaming. They work independently for folding even with SLI enabled though. Each GPU gets its own WUs. I don't think it makes a difference whether you connect the SLI bridge or not as far as folding goes.
A couple more hours and it's the end of endgadget.
Second 970 up and running (I needed a shoehorn to fit it in my case)
Reactions: Foxbat
Disappearance - 103 W AMC1/Spaceway 1/DirecTV 10/DirecTV 12
Software Update Coming
Users Who Are Viewing This Thread (Total: 4, Members: 0, Guests: 4)
