HWS problem?
bnewt
1,440
469
Shepherdsville, Ky
Today my HWS started acting up............
have hdmi connected to tv, component to distant tv via cat 5. This a.m., the picture on the distant tv started fading on & off with the "no signal" warning on the screen. Is the the HWS going bad or something else?
Might be the device that you are using to convert the component to cat 5....
Aside from the device failing you may want to see if a different patch cable helps. Is there anything new near the cable that could be causing interference? Power cords etc.
