I've owned satellite TV equipment for 30 years, starting with a 10-foot dish. My current setup is about 15 years old.
My Dish500 is pointed at 110, 118, and 119. A DP34 switch selects one of those 3 feeds for each of 2 coaxes down to my 2-channel receiver, an ancient Dish 4000.
I have run the switch test (Point Dish menu). It gives a "fewer satellites" message but I did NOT save the new settings since nothing was supposed to have changed.
One of the channels receives all 3 satellites. The other shows 119 when 110 is selected.
I replaced the DP34 switch with a new one from eBay. No change.
I switched the coaxes at the receiver. The problem switched to the other channel.
I moved the coax at the DP34 from output 2 to output 3, then to output 4. No change.
I'm not positive but the problem may have switched from one channel to the other just by running the switch test.
Signal strengths seem a bit low but as I said the one channel receives all 3 satellites OK. 118 is much weaker but I think that's normal.
I cannot figure out what the cause could be or how to fix it.
Ideas?
Ideas?
