One tv in the house can't have 4k, but then you knew that!That's an interesting scenario ....
They always say to put the C61k on the 4k TV and the Genie on a different TV . ...
That doesn't address the only one TV or recvr in the house scenario ....
Wonder what they do in that scenario ?
They could put both the HR54 and C61k on the same TV I guess but it seems like an odd thing to do.
You would actually have to change in puts to watch the 4k, unless you used the C61k for the main box, then the HR54 basically is a DVR .....
Wonder how often they come across this ?
The HS17 would basically be the same situation with only one tv.
the c61k is not a receiver, its a client
it requires a genie to work
I was having installed on Saturday and when they placed the order they put I had 2 tvs. When he came out to install and know where everything was he told me that the ordered it as I had 2 tvs. He tried to talk me into using the TVs built in box but I said I was ok with the 2 units. He also told me that he would not have just ordered this for 4k since in his opinion it was a very limited technology as of today. So that is why I was asking about a signal box or if one was coming. So I told him that if that is what his recommendation was then cancel the install.One tv in the house can't have 4k, but then you knew that!![]()
What he was getting at is that there' very little out in 4k so far.I was having installed on Saturday and when they placed the order they put I had 2 tvs. When he came out to install and know where everything was he told me that the ordered it as I had 2 tvs. He tried to talk me into using the TVs built in box but I said I was ok with the 2 units. He also told me that he would not have just ordered this for 4k since in his opinion it was a very limited technology as of today. So that is why I was asking about a signal box or if one was coming. So I told him that if that is what his recommendation was then cancel the install.
That CAN'T be true ....One tv in the house can't have 4k, but then you knew that!![]()
I phrased that really poorly. You can't have 4k with only one box. You need a Genie and a 4k client, the C61k. That's what I meant to say the first time.That CAN'T be true ....
So a person with only 1 TV can't have 4k, that' ridiculous ..... it will cost you extra but you should be able to do it ....
Now That makes more sense .....I phrased that really poorly. You can't have 4k with only one box. You need a Genie and a 4k client, the C61k. That's what I meant to say the first time.
I strongly suspect that the goal is to have as many server/client setups as possible going forward. I'd be shocked to see a new receiver/dvr at this point.
Commercial!
They are not at the point with genie and clients, especially large hotels
Well, I have only one TV so when I had my first 4K setup with DirecTV I had an HR54 and a C61K hooked up to the same TV. Now I have an HS17 and a C61K.That CAN'T be true ....
Not quite right. If your TV has RVU capability, you don't need the client.I phrased that really poorly. You can't have 4k with only one box. You need a Genie and a 4k client, the C61k. That's what I meant to say the first time.
True, but rvu used as the client still costs $7/month and although not a physical box box it is required.Not quite right. If your TV has RVU capability, you don't need the client.
