Hopper Remote "Special" Key Combinations
charlesrshell
SatelliteGuys Crazy
11,298
6,045
O'Fallon, IL
I used that procedure early this morning to force my Wally to take the latest software download. Since then, it does not seem to have the problem that I had previously with the Wally automatically turning itself back on after the Daily Reset.
Did you have to re-activate?
pattykay
formerly crodrules
Jun 14, 2014
8,620
7,751
North Central Ohio
No. Since the receiver is already activated, it skips that step and goes straight to the software download. Do keep in mind that doing this procedure will erase any custom Settings, so you would have to go back through the Menu to reset everything the way you want it afterward. DVR timers will not be lost, though.
charlesrshell
SatelliteGuys Crazy
11,298
6,045
O'Fallon, IL
Thanks. This is good info to try as a last resort to fix things.
JSheridan
8,899
10,030
USA
I wonder if some of the Hoppers that are having strange issues if something went wrong during the installation download.
Nah. It just downloads the current software that's in the stream. When a new version comes along then that's replaced. Along the way I've had a few of those Hoppers that were having 'strange problems' and I've tried the whole bag of tricks including this one and it made no difference.
It's just a fact that every Hopper has it's own individual personality and it's own quirks. :)
charlesrshell
SatelliteGuys Crazy
11,298
6,045
O'Fallon, IL
I think some Hoppers have ghost! :eek:
littlecloud319
Tech guru
May 22, 2017
524
365
Black Creek WI
Here is a couple of PDF files I made a while back to help me with the 54.0 and 50.0 remotes if someone wants to use them.
That button guide should be in a pinned thread for easy access/reference. And maybe one for the 52 although as far as i know its the same minus voice input.(and layout)
Sent from my SM-G950U using the SatelliteGuys app!
Bruckyboo
Jan 13, 2010
4
Jamaica
@ JSheridan...You are correct. Skip back, Recall, Skip back. Used when the Hopper is stuck on the DL screen too long. This happens sometimes when activation is sent but hasn't kicked in for one reason or another. You are then able to access the menu and do a check switch to ensure the configuration is correct.
Haven't posted in a looking time and the white button didnt seem to work for me
Recordings ending prematurely? Hopper 3
Hopper 3 internal resets
