Here is instructions for the DPP44 switch if it helps.I'm trying to setup two legacy SW44's for a friend who uses large single dishes instead of DPP equipment. He wants to add a fifth receiver. Is there a diagram out there?
Legacy equipment should no longer function on DISH systems. Receivers older than VIP are discontinued and most VIP receivers are on the border line or are discontinued.
However there are no legacy receivers so that's a mute issue.
Actually it's a moot issue.![]()
Will that do 5 receivers?Very easy!
Get (4) high frequency (900-2050) MHZ 2 way power passing splitters.
Put it on each of the 4lines coming from the dish and run into each switch.
Make sure the splitter on port 1 is also used for port 1 on the other switch.
Do the same for port 2,3 and 4
The splitters can be all port power pass or single port power pass and either 40-2050 MHZ OR 900-2050 MHz.
you can get them cheap online or I believe HOME DEPOT has the right splitters in their electrical dept
I thought the 44 switch had outputs to run into a second 44 switch?
SW44, NOT dp44 plus
You're right, I've been out of the business too long. Remember this?
