Hopper Upgrade Software Tool Sequence of Events
charlesrshell
SatelliteGuys Crazy
11,434
6,194
O'Fallon, IL
To help fellow SatGuy members that have trouble using the Upgrade Software tool, I have made a list of sequence of events that take place. Or at least this is my usual experience using the Upgrade Software tool. Follow the following procedure and see if you have better results. After you perform step one, set your remote control down and do not touch it again till the last screen appears in step 8. Upgrade takes about 25 to 30 minutes to perform. Be patient.
1. The Upgrade Software Tool is located in the Diagnostics menu. For the 54.0 remote control press Home button three times, scroll to Tools, then select the Upgrade Software icon. For the 40.0 remote control press the Menu button two times.
2. Popup 1573 Upgrade Software appears. Select Upgrade Now.
3. About a minute later the Hopper 3 Starting Up screen appears.
4. In about two minutes the DISH screen saver screen appears.
5. About a minute later popup 061 Warning Vital Program information screen with the download scroll bar appears.
6. In about thirteen minutes the popup 303 Warning Your receiver's memory is now being programed appears.
7. In about seven minutes the Hopper 3 Starting Up screen appears.
8. In about two minutes the DISH screen saver appears again.
9. Now you can press the SAT button on your remote control and live TV should come on.
Sometimes after the update is complete you might get a popup 498 Attention Updating Remote. Set your remote control down and do not disturb it while it is being updated. I think this takes about 10 to 15 minutes.
Thanks for the How-To. Learned new shortcuts!
Didn't know about the Shortcuts. My previous route on the 54: Home Button Two Times>Scroll to Settings>Select>Scroll to Diagnostics>Select>Scroll to Tools!
The 40.0 remote, never tried it for Settings, now will be my Go-To...Again, Thank-U!
You are welcome. Scott posted good info too on unplugging the Joeys. That is probably another reason folks have trouble upgrading their Hopper software is because there is a Joey turned on someplace in their Hopper/Joey system.
Reactions: LQQK
The first time I tried to do this a year or so ago, I dumped out early because I thought the Hopper had frozen up. Excellent post, charlesrshell. Thanks! This should be a sticky.
Thanks Rolling Joe. I use to think it was frozen up too, got pissed and then quit. I think the biggest reason folks have issues because they quit early and there is a Joey on someplace.
Streaming too in disputes
MLB Extra / NHL Center Ice Question
