Smart Card Not Inserted 019
As someone that has switched from 211k's to Wallys I can say for a fact that when you switch the Wally will reformat the EHD.
100 hours of shows I been meaning to watch...feels like it did when I had a EHD fail. LoL
Got my wally today. Will it work fine with a eastern arc? I'm having issues aquiring a signal..... : /
I hoope so, since I live in an EA market and innstall them all the time.
Have you tried backing out and running a check switch (Or Test Installation) manually? Wallys are odd creatures, I've had it only show 1 sat, download,, program memory, reboot, test installation and show all sats without me touching anything
Reactions: JSheridan
Just did the test switch it found all 3 satellites with a check under each one. It seems to be thinking about working right now. Fingers crossed. lol.
When I was calling to get it activated they asked if I lived in a RV ..odd question....are these for RV use?
I ordered a wifi adapter but I haven't received it yet. Now just have to reschedule all my timers.
I have real nice remote. It has voice commands I believe I haven't messed with it yet.
54. When you're done updating, hit Home, go to Settings, TV - Click on Pair TV Wizard, put in your Make of TV, it'll do a scan, then check the Volume. If it works, hit Save and the remote will work your TV. If you have AV, do the same thing for Auxiliary Device. A sound bar is an Audio Accessory and a Receiver is, obviously, an Audio Receiver. After it scans, you have to press the AUX button on the side, then check the volume. If it works, hit SAT on the side and save it, then scroll down further and change Default Volume and Mute to Auxiliary Device.
After that, back out, go to TV, set your resolution, drop down to Screen Size and adjust it so the green circle fit into the corners.
Thanks for your help.
Also, you need a USB WiFi Adapter or direct Ethernet connection for Voice and the apps to work
USB wifi adapter on its way then everything will work. This receiver is a lot nicer than the old VIP211k and a lot smaller. :)
Reactions: HipKat
How do I find IP address of Joey3 HW?
Installed a RAID for EHD
