Good morning, rodder! We don't recommend turning that feature off, but we can get you to the right screen. On your remote, if you have a house button, if you press it twice, then go to settings, power, inactivity timeout, you can extend or even turn the feature off completely. On your remote, if you have the menu button, you'll press it once, then settings, power, inactivity timeout. -- Jake BHow do i stop my Hopper 3 from asking me to push a button to watch tv?
Thanks but it is already offGood morning, rodder! We don't recommend turning that feature off, but we can get you to the right screen. On your remote, if you have a house button, if you press it twice, then go to settings, power, inactivity timeout, you can extend or even turn the feature off completely. On your remote, if you have the menu button, you'll press it once, then settings, power, inactivity timeout. -- Jake B
I didn't think of that one. You are probably correct. In that case, the OP should just ignore it becaue it will go into standby in 5 minutes. It is a great feature. One should not allow it to cause great consternation. It does this every time I shut of my Joeys, and it is no biggie. Again, I like this feature because sometimes I do use it. The Joey and even H3 itself uses a minimum amount of electricity and it is only for 5 minutes.I believe what he's talking about is the 5 minute standby/countdown in which case, you cannot disable it. It's there for a specific reason
If you see the countdown, it will go into standby at the end of the countdown. I've verified this. On the other hand, use one of the older remotes to put the box into standby immediately.I always use the 54 remote voice command "turn off" on both of my Hopper3 receivers and my Joey3. I realize that they will shut off on their own after 5 minutes but I like to verify that they are off.
