For Election 2020, It’s IP In A Landslide
kofi123
381
637
Minnesota
Here's an interesting article sharing the perspectives of ABC, CBS, Fox News, Meredith, and Hearst about the methods they intend to use in backhauling live events related to the 2020 elections. Unsurprisingly, given trends over the past decade, the overwhelming majority of all feeds will use IP, but traditional DVB satellite will still be used for certain purposes.
This part of the story was pretty interesting: Hearst is unique in that it still has a dedicated Ku-band transponder that it uses to cover breaking news across the group.
Anyone know where that "dedicated" transponder is?
I am very curious: What is a "fiber truck" as discussed in the TVN Tech article? How can a truck out in the field use fiber optic cable?
I was thinking about HEVC feeds on 99W* and other birds for news feeds too. :)
For some reason HEVC's codecs is easier to lock in depending on SNR or heavy traffic on the birds. :)
I noted that on 65W* is loaded with HEVC and it's very weak signal coming in New Mexico at upper 20 to 30% and still able to locked in with good pictures.
Of course the they have technical problems on their part from somewhere in Caribbean.
That's about what I see HEVC looks like in real signal environment even though it's a wideband signal carrier.
We shall see what ENG narrowband HEVC's looks like and hopefully easier to lock in.:hungry
As HEVC is a CODEC rather than a modulation scheme, it shouldn't make a whole lot of difference reception-wise.
I reason that it is possible that they're spending some of the bandwidth savings on more FEC, but what's on the carrier shouldn't significantly impact the ability to capture the carrier.
Forcing those to deliver the programming to transcode seems like bad policy.
