Here's a good forum for tv antenna stuff: HDTV TechnicalIs the tuner in those about as good as in TV..or better, worse?
I have DB8e antenna with rotor, anyone know of forum that still around
with tv antenna talk
thanks
My AirTV dual tuner adapter picks up 67 channels and my Roku TV also picks up 67. Of course, I didn't spring for a fancy DB8E 8-element bowtie.Is the tuner in those about as good as in TV..or better, worse?
My Sony's tuner beats my Dish OTA. My ABC station drops out on my DISH DVR, but not on my Sony TVIs the tuner in those about as good as in TV..or better, worse?
thanks
My DB8e isn't all that great, I pick up two more channels with it than I do with $6.00 indoor from ebayIs the tuner in those about as good as in TV..or better, worse?
thanks
You could try this: Amazon product ASIN B01KW8LAG2Since you guys are so knowledgeable, Peoria local channels are within <20 miles of any antennas and I pick those up with no issues with my Televes that Dish still sells. It's about 20' in the air, pointing slightly East North East at about 110 °.
Over >50 - 75 miles away to the southeast if I could reach that far, are the Champaign/Springfield/Decatur locals. I'd like to hit both using, if needed 2 Antennas combined, but trying to find that longer-range Antenna is daunting with so many out there. And how to combine 2 into one feed?
Must be an Amazon link. Can you just post the name?? The link isn't showing up.You could try this: Amazon product ASIN B01KW8LAG2
No guarantees that it will work, look at the comments, but it's $20 and might be worth a try.
Channel Master CM 0050 JOINtenna TV Combiner.Must be an Amazon link. Can you just post the name?? The link isn't showing up.
Wouldn't a two way coax spliter work to combine two antenna inputs?You could try this: Amazon product ASIN B01KW8LAG2
Technically YES, in actual real life, rarely. It all depends on where you live, and what directions the two antennas are aimed in, and if they have fairly tight beams. If they both receive the same station(s) it can wipe out the signal completely on that one channel at least.Wouldn't a two way coax spliter work to combine two antenna inputs?
I'm running to the TV and using the TV Tuner, but good to know!Better to use two antennas and at the TV/tuner connect them with a switch, not a combiner. The uvsj combiner us to join VHF channels with UHF channels and that is not your case.The splitter reversed as a combiner is ok for strong signals but it radiates 1/2 of each signal out the other antenna so for fringe reception it is not practical.
This presents another problem since the Dish USB tuner is not capable of adding channels with a scan with present software. Might have to play with the switch as the scan proceeds so the proper anteena is selected as the tuner scans frequencies (lots a luck).
I haven't personally tried it yet, but I read that you also need to have the same length of coax from the antennas to the combiner. There was an explanation for this requirement but I forgot it.Technically YES, in actual real life, rarely. It all depends on where you live, and what directions the two antennas are aimed in, and if they have fairly tight beams. If they both receive the same station(s) it can wipe out the signal completely on that one channel at least.
