I think you are mixing up Margo with Woody, Woody is the OP for this thread. Margo came in a little later with similar issues. Margo has a 722, as she just told us, and Woody has a Hopper.
That's correct, mine is a Hopper.
And if that doesn't work, give it a "hit" from MyDish. That worked for me on a disk I hadn't used in years (while others worked fine).Unplug the EHD from the 722. Now, after doing that do unplug from power reboot the 722. After it boots up plug the EHD back in. If that doesn't fix it unplug that EHD again and give it a few days and then try replugging it.
I unplugged the dvr, waited then plugged it back in and rebooted. Now it went from "must be reformated" to "unsupported device" to "must be reformated" and back to "unsupported device", which is where it's at now.And if that doesn't work, give it a "hit" from MyDish. That worked for me on a disk I hadn't used in years (while others worked fine).
Also, when you say give it a "hit" from MyDish what does that mean? Do you mean contact Dish online?I unplugged the dvr, waited then plugged it back in and rebooted. Now it went from "must be reformated" to "unsupported device" to "must be reformated" and back to "unsupported device", which is where it's at now.
