110/119 Listings Post 129 Transition (Updated 9/1/2025)
zippyfrog
2,175
1,922
Chicago, IL
Over the past year I have been tracking the changes on Western Arc. The past 3 months have had a lot of changes that I posted in the other MPEG2 Western Arc shutdown thread. Now that 129 is (basically) out of commission, here is where Western Arc stands. This is just a national channel list, (no local channels) based off what I can see and what others have contributed. Thanks to everyone who has helped me come up with the locations of some of the channels – I would try and list all of you out, but I know I would forget someone! As has been suggested in other parts of the forum, it would be great to collect the spotbeam data for those who could contribute!
A couple of pieces of info:
  • Out of the 64 transponders between 110/119, there are currently 50 transponders that Dish is licensed to use. 22 are Spotbeams, 28 are ConUS transponders (14 transponders are licensed to DirecTV and Dish doesn't have access to them)
  • Those 28 ConUS transponders are divided as follows:
    • 10 are dedicated to National HD channels (ESPN, CNN, Disney Channel, etc). Dish is maxing out at 16 HD channels per transponder (note – in an earlier post I said there was one transponder with 17 HD channels, that was an error on my part. When I double checked my listings, one channel changed transponders). Before the transition, there was a maximum of 14 HD channels per transponder.
    • 1 transponder is dedicated to adult content
    • 2 are a mixture HD PPV Movies/4k channels
    • 3 are set aside for HD Sports channels that are only on for live games (NBA League Pass, the PAC 12 alternate channels, some PPV events, etc); 3 SD PPV Sports Channels are there as well.
    • 7 are for SD and/or music channels. Dish is maxing out at 26 SD channels per transponder thus far on the SD transponders.
    • 5 transponders on 110 I have no channels listed but Dish operates. (they are labeled as ConUS on my chart below) There are other things that could be on those transponders, like RV Distant Networks, internal testing channels, etc, that I can't see. They might be able to be used for additional content, but I am not sure exactly what is on those transponders.
There are two transponders that have lower than normal SD channels – 110, TP 21 and 119, TP 19. Previously those transponders contained the programming guides that get downloaded from the satellite when the receivers download EPG. I assume that is where the programming guides are still downloaded from, thus less channels there.
When I talk about number of channels on a transponder, all my numbers are unique channels – for example, channel 101 and 199 are the same channel mapped to two different numbers, but in terms of space, only takes up 1 channel worth of bandwidth on the transponder.
Finally, I have to give Dish a ton of credit. When it was 110/119/129, Dish had 82 transponders they were using – it took a lot to get it down to 50 transponders and figure out where all the pieces were going to go. What are the things they did to get there? Here are the things I saw:
  • During this migration from 129, Dish converted 7 ConUS transponders on 119 into Spotbeams – that is how they ended up fitting on all the HD locals that used to be on 129. (for those interested, TP 6, 7, 8, 9, 10, 11, 13 are the ones that used to be ConUS on 119 that are now Spotbeam)
  • Removed almost all SD duplicate channels that are offered in HD
  • Converted remaining SD channels from MPEG2 to MPEG4
  • There are also 2 subtle things that changed from the HD channel perspective
    • At the beginning of the transition, Dish decreased the number of PPV Movie channels – prior to this transition the PPV channels HD PPV movies were 502-522; now they are 502-517.
    • At the beginning of April when MLB, NBA, and NHL regular seasons were all going on at the same time and this transition began, there were a ton of games "joined in progress" for the HD feeds. That wasn't common since the days before the full time HD RSN's. The reason for that was prior to the transition, Dish had 4 transponders set aside for HD Sports – 2 transponders was the bandwidth set aside from the HD RSN's before Dish dropped the RSN's, then 2 transponders were for alternate channels. Now we are down to 3 transponders for HD sports.
As of 11/29/24: Here is a breakdown of what is on each transponder (nationally):
Transponder110119
01SD (4) - Distant NetworksSpotbeams
02ConUSSpotbeams
03SD (20), Music (31)Spotbeams
04SpotbeamsSpotbeams
05SD (24), Music (1)Spotbeams
06ConUSSpotbeams
07HD PPV (12), HD (1)Spotbeams
08HD - PPV (5), 4K (4)Spotbeams
09HD - Sports (16 feeds at a time)Spotbeams
10SD (25)Spotbeams
11ConUSSpotbeams
12SpotbeamsHD (16)
13HD (14)Spotbeams
14HD (4)HD (16)
15HD - Sports (16 feeds at a time)Adult - SD (14); HD (1)
16SD (26)SD (22), Music (33)
17ConUSHD (16)
18SpotbeamsHD (15)
19HD (16)SD (11), Music (29)
20SpotbeamsHD (16)
21SD (4), Music (31), HD (3)HD (16)
22HD (16)N/A
23SpotbeamsN/A
24SD/HD Sports PPV (3 each); HD (1); SD (1)N/A
25SpotbeamsN/A
26SpotbeamsN/A
27SpotbeamsN/A
28N/AN/A
29SpotbeamsN/A
30N/AN/A
31SpotbeamsN/A
32N/AN/A
Here are the listings by channel (as of 9/1/2025):
ChannelTypeNetworkSatellite/Transponder
70HDHSN119, TP 21
71HDQVC119, TP 17
72SDValue119, TP 16
73SDQVC3110, TP 05
75SDRenew119, TP 16
76SDDeal119, TP 16
81SDICTV110, TP 10
82SDFETV119, TP 19
83SDJTV110, TP 10
84SDBuyTV (same as 283 and 9458)110, TP 05
85SDEPIC119, TP 16
86SDMALL119, TP 16
87SDShop119, TP 16
101HDDish Scapes119, TP 14
102HDBonus View Information110, TP 07
104SDValue (same as 72)119, TP 16
105HDUSA119, TP 12
106SDTV Land119, TP 19
107HDComedy Central119, TP 12
108HDLife119, TP 12
109HDLMN119, TP 12
110HDFood Network119, TP 12
111HDMagnolia110, TP 07
112HDHGTV119, TP 12
113HDCooking Channel110, TP 19
114HDE!119, TP 18
116HDGame Show Network119, TP 14
117HDPOP119, TP 14
118HDA&E119, TP 17
119HDFYI119, TP 14
120HDHistory119, TP 21
121HDVice110, TP 19
122HDSYFY119, TP 21
123SDMALL (same as 86)119, TP 16
124HDBET119, TP 18
125HDFXX110, TP 13
126HDSundance119, TP 14
127SDOxygen119, TP 19
128HDWE119, TP 18
129HDBravo119, TP 20
130HDHD Net Movies119, TP 21
131HDAMC119, TP 17
132HDTCM119, TP 17
133HDIFC119, TP 14
135HDBBC America119, TP 20
136HDFX119, TP 12
137HDQVC119, TP 17
138HDTNT110, TP 21
139HDTBS119, TP 12
140HDESPN119, TP 21
141HDESPNU110, TP 19
142HDESPNews110, TP 22
143HDESPN2119, TP 18
149HDFox Sports 2110, TP 22
150HDFox Sports 1119, TP 18
152HDMLB Network119, TP 14
153HDMLB Strikezone110, TP 09
154HDNFL Network119, TP 12
155HDNFL Redzone (via 9467)110, TP 15
156HDNBA TV119, TP 20
157HDNHL Network119, TP 14
158HDCBS Sports Network119, TP 21
160HDMTV119, TP 12
161SDMTV2119, TP 16
162HDVH1119, TP 18
163SDMTV Classic110, TP 10
164HDFuse110, TP 13
165HDGfamily110, TP 22
166HDCMT119, TP 20
167HDAXS110, TP 22
168SDDisney Jr119, TP 19
169SDNick Jr119, TP 19
170HDNickelodeon119, TP 17
171SDNick West119, TP 16
172HDDisney Channel110, TP 19
173SDDisney Channel (West)119, TP 19
174SDDisneyXD119, TP 19
175SDBoomerang119, TP 19
176HDCartoon Network119, TP 12
177SDCartoon Network (West)110, TP 10
178SDNickToons119, TP 16
179HDDiscovery Family119, TP 20
180HDFree Form110, TP 19
181SDTeen Nick119, TP 16
182HDDiscovery119, TP 12
183HDTLC119, TP 18
184HDAnimal Planet119, TP 14
185HDHallmark Channel119, TP 18
186SDHalmark Drama119, TP 16
187HDHallmark Movies110, TP 07
188HDUP119, TP 21
189HDOWN119, TP 12
190HDNatGeo Wild119, TP 17
192HDID119, TP 20
193HDScience119, TP 20
194HDDest. America110, TP 13
195HDAHC119, TP 12
196HDTravel Channel119, TP 21
197HDNatGeo119, TP 18
199HDDish Scapes119, TP 14
200HDCNN119, TP 17
202HDHLN110, TP 19
203HDBITV110, TP 13
205HDFox News119, TP 12
206HDFox Business119, TP 14
207HDNewsNation119, TP 21
208HDCNBC119, TP 18
209HDMSNBC119, TP 18
210SDCSPAN110, TP 05
211SDCSPAN2110, TP 10
212HDOAN110, TP 21
214HDWeather Channel119, TP 17
215HDWeatherNation110, TP 22
216HDNewsmax119, TP 20
217SDGrit119, TP 19
218SDBinge110, TP 16
219SDAmerica's Voice110, TP 05
220SDMALL (same as 86)119, TP 16
221SDExtra119, TP 16
222HDFox Weather110, TP 13
223SDRenew (same as 94)119, TP 16
224SDEpic (same as 85)119, TP 16
225SDSale119, TP 16
226SDHSN2110, TP 10
227SDJTV (same as 83)110, TP 10
228SDYouTV119, TP 16
229SDGems110, TP 10
230SDICTV (same as 81)110, TP 10
231HDRFD110, TP 22
232HDCowboy Network110, TP 19
233HDCowgirl 110, TP 19
234SDSuperstation - WPIX110, TP 05
235SDSuperstation - KWGN110, TP 05
236SDSuperstation - WSBK110, TP 05
237SDSuperstation - KTLA110, TP 05
238SDSuperstation - WWOR110, TP 05
239SDLAFF110, TP 16
240SDJustice110, TP 10
241HDParamount Network110, TP 21
242HDTruTV119, TP 20
243SDFM110, TP 10
245SDBuzzr119, TP 16
246HDMT110, TP 07
248HDGLIV110, TP 19
249HDCrime and Investigation110, TP 22
250SDION119, TP 19
251HDBET Her110, TP 13
254HDLogo110, TP 13
255SDQVC2110, TP 05
256SDBible110, TP 05
257SDSBN110, TP 03
258SDTBNI110, TP 03
259HDInspiration110, TP 19
260HDTBN110, TP 21
261SDEWTN110, TP 03
262SDCTN110, TP 10
263SDDaystar110, TP 05
264SDImpact110, TP 03
265SDVictory110, TP 03
266SDTCT110, TP 03
267SD3ABN110, TP 05
268SDBYU TV110, TP 05
269SDFree Speech TV110, TP 10
270HDUnivision119, TP 14
271HDUnimas (same as 830)119, TP 21
273HDGalavision119, TP 18
274SDNRB TV110, TP 10
275SDYouTV (same as 228)119, TP 16
276SDSmart (same as 87)119, TP 16
277SDRenew (same as 75)119, TP 16
278SDDeal (same as 76)119, TP 16
282SDValue (same as 72)119, TP 16
283SDBuyTV (same as 84)110, TP 05
285SDDOG TV119, TP 16
287HDHSN119, TP 21
288SDExtra (same as 221)119, TP 16
289HDComet110, TP 22
291SDStart110, TP 05
292SDMGM+D110, TP 03
293SDHero and Icon110, TP 05
294HDAMC+119, TP 18
299HDReelz119, TP 14
307HDCinemax East110, TP 14
308HD5 Star Max110, TP 19
310HDHBO East119, TP 20
311HDHBO West119, TP 12
312HDHBO 2119, TP 20
313HDHBO Latino110, TP 21
318HDShowtime East110, TP 13
319HDShowtime West119, TP 21
320HDShowtime Too119, TP 17
321HDShowtime BET110, TP 13
322SDShowtime Extreme110, TP 16
323SDShowtime Showcase110, TP 10
324HDShowtime FamilyZone119, TP 21
327HDMovie Channel East110, TP 13
328SDTMCXE110, TP 03
329SDTMC-W110, TP 10
330SDTMCXW110, TP 10
333SDFLIX110, TP 10
340HDEncore110, TP 19
341HDEncore West119, TP 14
342HDEncore Western119, TP 20
343SDEncore Action110, TP 03
344HDEncore Suspense119, TP 14
345SDEncore Black110, TP 03
346SDEncore Classic110, TP 03
347SDEncore Family110, TP 03
348HDEncore Esp110, TP 14
349HDBonus View Information110, TP 07
350HDStarz119, TP 18
351HDStarz West110, TP 13
352HDStarzEdge110, TP 13
353SDStarz Cinema110, TP 10
354HDStarz Comedy119, TP 21
355SDStarz In Black110, TP 10
356HDStarz Family119, TP 21
359SDBounce110, TP 10
360SDGrio110, TP 16
362SDBET Gospel110, TP 10
363SDBET Soul110, TP 03
364SDCMT Music110, TP 03
365SDBET Jams110, TP 10
366SDMTVU110, TP 16
367HDSmithsonian110, TP 22
368SDNick Music110, TP 16
369HDMTV Live110, TP 13
373SDGet TV110, TP 10
374SDAWE110, TP 05
377SDMoviePlex110, TP 10
378HDIndieplex110, TP 21
379HDRetroplex110, TP 22
380HDMGM+110, TP 13
381HDMGM+ Hits110, TP 14
382HDMGM+ Marquee110, TP 13
384HDFXM110, TP 22
386HDSony110, TP 22
388HDPIXL110, TP 22
390SDOutside Television110, TP 16
391SDFox Soccer Plus110, TP 05
392HDBEIN119, TP 17
394SDWorld Fishing Network110, TP 03
395HDSportsman Channel110, TP 22
396HDOutdoor Channel119, TP 20
397HDTUDN110, TP 14
399SDFanDuel Racing110, TP 10
400HDTennis Channel110, TP 21
401HDGolf Channel119, TP 14
402HDACC Network119, TP 17
404HDSEC Network110, TP 19
410HDBig 10119, TP 18
440HDSports Alternate110, TP 09
441HDSports Alternate110, TP 09
442HDSports Alternate110, TP 09
460HDSports PPV110, TP 07
461HDSports PPV119, TP 17
464SDPPV Sports119, TP 16
465SDPPV Sports119, TP 16
466SDPPV Sports119, TP 16
472HDSports PPV119, TP 16
474HDSports PPV119, TP 16
477HDNHL Network Alternate110, TP 15
478HDMLB Network Alternate110, TP 15
481SDPPV Adult119, TP 15
482SDPPV Adult119, TP 15
483SDPPV Adult119, TP 15
484SDPPV Adult119, TP 15
485SDCheap Thrills119, TP 15
487SDPlayboy Spanish119, TP 15
489SDPlayboy119, TP 15
490SDBrazzers TV119, TP 15
491SDReal Extreme119, TP 15
492SDVivid119, TP 15
494SDTEN119, TP 15
495SDReality Kings119, TP 15
496SDHustler119, TP 15
497HDHustler119, TP 15
498SDXtasy119, TP 15
500HDBonus View Information110, TP 07
502HDPPV Movies110, TP 07
503HDPPV Movies110, TP 07
504HDPPV Movies110, TP 07
505HDPPV Movies110, TP 07
506HDPPV Movies110, TP 07
507HDPPV Movies110, TP 07
508HDPPV Movies110, TP 07
509HDPPV Movies110, TP 24
510HDPPV Movies110, TP 24
511HDPPV Movies110, TP 08
512HDPPV Movies110, TP 08
513HDPPV Movies110, TP 08
514HDPPV Movies110, TP 24
515HDPPV Movies110, TP 08
516HDPPV Movies110, TP 24
517HDPPV Movies110, TP 24
588HDBig 10 Alternate110, TP 09
589HDBig 10 Alternate110, TP 15
590HDBig 10 Alternate110, TP 24
591HDBig 10 Alternate110, TP 09
818HDSports PPV119, TP 16
821SDCLAN110, TP 03
823SDBaby 1110, TP 10
824SDBaby110, TP 05
826SDWAPAA110, TP 10
827HDUnivision (same as 270)119, TP 14
828SDUnivision West110, TP 05
829HDIPT119, TP 17
830HDUnimas (same as 271)119, TP 21
831SDMLMDS110, TP 16
832SDCentro110, TP 16
833HDGalavision (same as 273)119, TP 18
834SDPSNES110, TP 16
835SDTelemundo119, TP 19
836SDTelemundo110, TP 16
837SDTLNOV110, TP 16
838HDUniverso110, TP 22
839SDAnt3110, TP 16
840SDTVEI110, TP 16
841SDNTEL110, TP 16
842SDCrcol110, TP 03
843SDHistory Channel Spanish110, TP 16
844SDNat Geo Mundo110, TP 03
845HDDiscovery Spanish119, TP 14
846SDDS Fam110, TP 16
847SDUforo110, TP 16
848SDMLNIO110, TP 16
849SDCNN Spanish110, TP 16
851SDCuba Max TV110, TP 05
852SDEstrella TV110, TP 03
854HDESPN Deportes119, TP 21
855HDFox Deportes110, TP 13
860HDBein Spanish119, TP 20
861HDBEIN (same as 392)119, TP 17
863SDMXCNL110, TP 16
864SDCsony119, TP 16
865SDCine Latino110, TP 16
880SDHITN110, TP 05
881SDTDV110, TP 05
883SDValue119, TP 16
888SDEnlace TV110, TP 05
890SDVDRLA110, TP 16
891SDTRS3110, TP 16
892MusicVmari119, TP 19
893MusicMojito119, TP 19
894MusicLa Musica119, TP 19
923MusicAud1119, TP 19
924MusicAud2119, TP 19
925MusicAud3119, TP 19
926MusicAud4119, TP 19
927MusicAud5119, TP 19
928MusicAud6119, TP 19
929MusicAud7119, TP 19
930MusicAud8119, TP 19
931MusicAud9119, TP 19
933MusicAud10119, TP 19
934MusicAud11119, TP 19
935MusicAud12119, TP 19
936MusicAud13119, TP 19
937MusicAud14119, TP 19
938MusicAud15119, TP 19
939MusicAud16119, TP 19
941MusicViva Mariachi (same as 892)119, TP 19
944MusicOtto1119, TP 16
945MusicOtto2119, TP 16
946MusicOtto3119, TP 16
950MusicCD1119, TP 16
951MusicCD2119, TP 19
952MusicCD3119, TP 16
953MusicCD4119, TP 16
954MusicCD5119, TP 16
955MusicCD6119, TP 16
956MusicCD7119, TP 16
957MusicCD8119, TP 16
958MusicCD9119, TP 16
959MusicCD10119, TP 19
960MusicCD11119, TP 19
961MusicCD12119, TP 19
962MusicCD13119, TP 19
963MusicCD14119, TP 19
964MusicCD15119, TP 19
965MusicCD16119, TP 19
966MusicCD17119, TP 16
967MusicCD18119, TP 19
968MusicCD19119, TP 19
969MusicCD20119, TP 16
970MusicCD21119, TP 16
971MusicCD22119, TP 16
972MusicCD23119, TP 16
973MusicCD24119, TP 16
974MusicCD25119, TP 16
975MusicCD26119, TP 16
976MusicCD27119, TP 16
977MusicCD28119, TP 16
978MusicCD29119, TP 16
979MusicCD30119, TP 16
980MusicCD31110, TP 05
981MusicCD32119, TP 16
997HDLivestock Auction110, TP 15
998HDDish Business Info110, TP 09
4385SDTBN - Inspire110, TP 03
4801SDForo TV (same as 847)110, TP 16
4803SDTL Novellas (same as 837)110, TP 16
5001HDNBA TV (Same as 156)119, TP 20
5002HDNBA League Pass - Celtics110, TP 15
5003HDNBA League Pass - Nets110, TP 15
5004HDNBA League Pass - Knicks110, TP 15
5005HDNBA League Pass - 76ers110, TP 15
5006HDNBA League Pass - Raptors110, TP 15
5007HDNBA League Pass - Bulls110, TP 15
5008HDNBA League Pass - Cavs110, TP 15
5009HDNBA League Pass - Pistons110, TP 15
5010HDNBA League Pass - Pacers110, TP 15
5011HDNBA League Pass - Bucks110, TP 15
5012HDNBA League Pass - Hawks110, TP 15
5013HDNBA League Pass - Hornets110, TP 15
5014HDNBA League Pass - Heat110, TP 15
5015HDNBA League Pass - Magic110, TP 15
5016HDNBA League Pass - Wizards110, TP 15
5017HDNBA League Pass - Mavericks110, TP 15
5018HDNBA League Pass - Rockets110, TP 15
5019HDNBA League Pass - Grizzlies110, TP 09
5020HDNBA League Pass - Pelicans110, TP 15
5021HDNBA League Pass - Spurs110, TP 15
5022HDNBA League Pass - Nuggets110, TP 15
5023HDNBA League Pass - Timberwolves110, TP 15
5024HDNBA League Pass - Thunder110, TP 15
5025HDNBA League Pass - Trailblazers110, TP 09
5026HDNBA League Pass - Jazz110, TP 09
5027HDNBA League Pass - Warriors110, TP 15
5028HDNBA League Pass - Clippers110, TP 15
5029HDNBA League Pass - Lakers110, TP 15
5030HDNBA League Pass - Suns110, TP 09
5031HDNBA League Pass - Kings110, TP 15
5330HDNHL Center Ice - Boston Bruins110, TP 09
5331HDNHL Center Ice - Buffalo Sabres110, TP 09
5332HDNHL Center Ice - Detroit Red Wings110, TP 15
5333HDNHL Center Ice - Florida Panthers110, TP 15
5334HDNHL Center Ice - Montral Canadiens110, TP 09
5335HDNHL Center Ice - Ottawa Senators110, TP 15
5336HDNHL Center Ice - Tampa Bay Lightning110, TP 09
5337HDNHL Center Ice - Toronto Maple Leaves110, TP 15
5338HDNHL Center Ice -Carolina Hurricanes110, TP 15
5339HDNHL Center Ice - Columbus Blue Jackets110, TP 09
5340HDNHL Center Ice - New Jersey Devils110, TP 15
5341HDNHL Center Ice - New York Islanders110, TP 15
5342HDNHL Center Ice - New York Rangers110, TP 15
5343HDNHL Center Ice - Philadelphia Flyers110, TP 15
5344HDNHL Center Ice - Pittsburgh Penguins110, TP 15
5345HDNHL Center Ice - Washington Capitals110, TP 09
5346HDNHL Center Ice - Arizona Coyotes110, TP 15
5347HDNHL Center Ice - Chicago Blackhawks110, TP 09
5348HDNHL Center Ice - Colorado Avalanche110, TP 15
5349HDNHL Center Ice - Dallas Stars110, TP 15
5350HDNHL Center Ice - Minnesota Wild110, TP 15
5351HDNHL Center Ice - Nashville Predators110, TP 15
5352HDNHL Center Ice - St. Louis Blues110, TP 15
5353HDNHL Center Ice - Winnipeg Jets110, TP 09
5354HDNHL Center Ice - Anaheim Ducks110, TP 09
5356HDNHL Center Ice - Calgary Flames110, TP 15
5357HDNHL Center Ice - Edmonton Oilers110, TP 15
5358HDNHL Center Ice - Los Angeles Kings110, TP 15
5359HDNHL Center Ice - San Jose Sharks110, TP 09
5360HDNHL Center Ice -Seattle Kraken110, TP 15
5361HDNHL Center Ice - Vancouver Canucks110, TP 09
5362HDNHL Center Ice - Vegas Golden Knights110, TP 15
5462HDMLB Extra Innings - Orioles110, TP 09
5464HDMLB Extra Innings - Red Sox110, TP 15
5466HDMLB Extra Innings - Yankees110, TP 15
5468HDMLB Extra Innings - Rays110, TP 15
5470HDMLB Extra Innings - Blue Jays110, TP 15
5472HDMLB Extra Innings - White Sox110, TP 15
5474HDMLB Extra Innings - Guardians110, TP 15
5476HDMLB Extra Innings - Tigers110, TP 15
5478HDMLB Extra Innings - Royals110, TP 15
5480HDMLB Extra Innings - Twins110, TP 15
5482HDMLB Extra Innings - Astros110, TP 15
5484HDMLB Extra Innings - Angels110, TP 15
5486HDMLB Extra Innings - Athletics110, TP 15
5488HDMLB Extra Innings - Mariners110, TP 15
5490HDMLB Extra Innings - Rangers110, TP 15
5492HDMLB Extra Innings - Braves110, TP 15
5494HDMLB Extra Innings - Marlins110, TP 15
5496HDMLB Extra Innings - Mets110, TP 15
5498HDMLB Extra Innings - Phillies110, TP 15
5500HDMLB Extra Innings - Nationals110, TP 15
5502HDMLB Extra Innings - Cubs110, TP 15
5504HDMLB Extra Innings - Reds110, TP 15
5506HDMLB Extra Innings - Brewers110, TP 15
5508HDMLB Extra Innings - Pirates110, TP 15
5510HDMLB Extra Innings - Cardinals110, TP 15
5512HDMLB Extra Innings - Diamondbacks110, TP 15
5514HDMLB Extra Innings - Rockies110, TP 15
5516HDMLB Extra Innings - Dodgers110, TP 15
5518HDMLB Extra Innings - Padres110, TP 15
5520HDMLB Extra Innings - Giants110, TP 15
6002MusicSXM02110, TP 21
6004MusicSXM04110, TP 21
6005MusicSXM05110, TP 21
6006MusicSXM06110, TP 21
6007MusicSXM07110, TP 21
6008MusicSXM08110, TP 03
6009MusicSXM09110, TP 21
6010MusicSXM10110, TP 21
6014MusicSXM14110, TP 03
6015MusicSXM15110, TP 03
6016MusicSXM16110, TP 21
6019MusicSXM19110, TP 03
6020MusicSXM20110, TP 03
6021MusicSXM21110, TP 03
6022MusicSXM22110, TP 03
6023MusicSXM23110, TP 03
6024MusicSXM24110, TP 03
6025MusicSXM25110, TP 03
6026MusicSXM26119, TP 16
6027MusicSXM27119, TP 16
6028MusicSXM28119, TP 16
6029MusicSXM29119, TP 16
6030MusicSXM30119, TP 16
6032MusicSXM32110, TP 03
6033MusicSXM33110, TP 03
6034MusicSXM34110, TP 03
6035MusicSXM35110, TP 03
6036MusicSXM36110, TP 03
6037MusicSXM37110, TP 03
6038MusicSXM38110, TP 03
6039MusicSXM39110, TP 03
6040MusicSXM40110, TP 03
6041MusicSXM41110, TP 03
6042MusicSXM42110, TP 21
6043MusicSXM43110, TP 03
6044MusicSXM44110, TP 03
6045MusicSXM45119, TP 16
6046MusicSXM46110, TP 21
6047MusicSXM47110, TP 21
6048MusicSXM48110, TP 21
6049MusicSXM49110, TP 21
6050MusicSXM50110, TP 21
6051MusicSXM51110, TP 03
6052MusicSXM52119, TP 16
6053MusicSXM53110, TP 03
6054MusicSXM54110, TP 03
6055MusicSXM55110, TP 21
6056MusicSXM56110, TP 21
6057MusicSXM57110, TP 21
6058MusicSXM58110, TP 21
6059MusicSXM59110, TP 21
6060MusicSXM60110, TP 21
6062MusicSXM62110, TP 21
6063MusicSXM63110, TP 03
6064MusicSXM64110, TP 21
6065MusicSXM65110, TP 03
6066MusicSXM66110, TP 21
6067MusicSXM67119, TP 16
6068MusicSXM68110, TP 21
6069MusicSXM69119, TP 16
6070MusicSXM70110, TP 21
6071MusicSXM71110, TP 03
6072MusicSXM72110, TP 03
6073MusicSXM73110, TP 03
6074MusicSXM74110, TP 21
6075MusicSXM75110, TP 21
6076MusicSXM76110, TP 03
6091MusicSXM91110, TP 21
6094MusicSXM94110, TP 21
6095MusicSXM95110, TP 21
6096MusicSXM96110, TP 21
9458SDBuyTV (same as 84)110, TP 05
9532SDICTV (same as 81)110, TP 10
9547HDBOOST Mobile Ad110, TP 14
540-014K4K Channel110, TP 08
540-024K4K Channel110, TP 08
540-034K4K Channel110, TP 08
540-044K4K Channel110, TP 08
VariesSDPBS Local (National Feed)110, TP 05
SDWCBS (CBS)- Distant Network110, TP 01
SDWNBC (NBC) - Distant Network110, TP 01
SDWNYW (FOX) - Distant Network110, TP 01
SDWABC (ABC) - Distant Network110, TP 01
Here is the same data sorted by transponder (as of 9/1/2025):
257SDSBN110, TP 03
258SDTBNI110, TP 03
261SDEWTN110, TP 03
266SDTCT110, TP 03
821SDCLAN110, TP 03
73SDQVC3110, TP 05
255SDQVC2110, TP 05
267SD3ABN110, TP 05
374SDAWE110, TP 05
824SDBaby110, TP 05
880SDHITN110, TP 05
881SDTDV110, TP 05
246HDMT110, TP 07
81SDICTV110, TP 10
83SDJTV110, TP 10
226SDHSN2110, TP 10
229SDGems110, TP 10
243SDFM110, TP 10
262SDCTN110, TP 10
333SDFLIX110, TP 10
125HDFXX110, TP 13
164HDFuse110, TP 13
203HDBITV110, TP 13
254HDLogo110, TP 13
380HDMGM+110, TP 13
397HDTUDN110, TP 14
239SDLAFF110, TP 16
360SDGrio110, TP 16
366SDMTVU110, TP 16
839SDAnt3110, TP 16
840SDTVEI110, TP 16
841SDNTEL110, TP 16
891SDTRS3110, TP 16
121HDVice110, TP 19
202HDHLN110, TP 19
248HDGLIV110, TP 19
138HDTNT110, TP 21
212HDOAN110, TP 21
260HDTBN110, TP 21
167HDAXS110, TP 22
231HDRFD110, TP 22
384HDFXM110, TP 22
386HDSony110, TP 22
388HDPIXL110, TP 22
105HDUSA119, TP 12
108HDLife119, TP 12
109HDLMN119, TP 12
112HDHGTV119, TP 12
136HDFX119, TP 12
139HDTBS119, TP 12
160HDMTV119, TP 12
189HDOWN119, TP 12
195HDAHC119, TP 12
117HDPOP119, TP 14
119HDFYI119, TP 14
133HDIFC119, TP 14
494SDTEN119, TP 15
72SDValue119, TP 16
75SDRenew119, TP 16
76SDDeal119, TP 16
85SDEPIC119, TP 16
86SDMALL119, TP 16
87SDShop119, TP 16
161SDMTV2119, TP 16
225SDSale119, TP 16
71HDQVC119, TP 17
118HDA&E119, TP 17
131HDAMC119, TP 17
132HDTCM119, TP 17
137HDQVC119, TP 17
200HDCNN119, TP 17
392HDBEIN119, TP 17
829HDIPT119, TP 17
114HDE!119, TP 18
124HDBET119, TP 18
128HDWE119, TP 18
162HDVH1119, TP 18
183HDTLC119, TP 18
208HDCNBC119, TP 18
294HDAMC+119, TP 18
82SDFETV119, TP 19
217SDGrit119, TP 19
250SDION119, TP 19
166HDCMT119, TP 20
192HDID119, TP 20
70HDHSN119, TP 21
122HDSYFY119, TP 21
140HDESPN119, TP 21
188HDUP119, TP 21
287HDHSN119, TP 21
From the locals perspective, I have access to the Chicago Locals, and here is where the Chicago locals are located. These are on spotbeam
2HDCBS110, TP 31
5HDNBC110, TP 31
7HDABC110, TP 31
9HDWGN110, TP 31
11HDWTTW119, TP 13
23HDMeTV119, TP 13
26HDCW-26119, TP 13
32HDFOX110, TP 31
38HDION119, TP 13
44HDTelemundo119, TP 13
48HDWMEU119, TP 13
50HDWPWR110, TP 31
56HDLakeshore TV119, TP 13
60HDTelefutra110, TP 31
61SDWPVN119, TP 13
62SDWJYS110, TP 31
66HDUnivision119, TP 31
Finally, I have not updated the sports channels that have changed each day. The sports packages have their channel jump between transponders 9, 15, and 24 each day depending on which teams are playing and how Dish has the feeds arranged on the satellites. Thus, those have not been checked on a daily basis.
Thanks for all your tracking. Great job zippyfrog.
Hey everyone - for those of you who subscribe to the local package and know how to check the satellite/transponder a channel is on, would you be willing to post where each of your local channels are? I have a master spreadsheet going on that it would be great to compile everything in one place.
So far, I was able to get all the Chicago locals. I have a friend who lives in Rockford and he told me what the Rockford locals are located - at least to the best of his knowledge. (Anyone here who lives in Rockford can confirm that these are correct?) He said there were only 4 channels and there is no ABC there - I am not quite sure he is completely accurate as 4 total channels seems low...and no ABC sounds strange.
MarketChannelTypeNetworkSatellite/Transponder
Chicago, IL2HDWBBM (CBS)110, TP 31
Chicago, IL5HDWMAQ (NBC)110, TP 31
Chicago, IL7HDWLS (ABC)110, TP 31
Chicago, IL9HDWGN110, TP 31
Chicago, IL11HDWTTW (PBS)119, TP 13
Chicago, IL23HDWWME (MeTV)119, TP 13
Chicago, IL26HDWCIU (CW-26)119, TP 13
Chicago, IL32HDWFLD (FOX)110, TP 31
Chicago, IL38HDWCPX (ION)119, TP 13
Chicago, IL44HDWSNS (Telemundo)119, TP 13
Chicago, IL48HDWMEU (The U)119, TP 13
Chicago, IL50HDWPWR (MyNetwork)110, TP 31
Chicago, IL56HDWYIN (Lakeshore TV)119, TP 13
Chicago, IL60HDWXFT (Telefutra)110, TP 31
Chicago, IL61SDWPVN119, TP 13
Chicago, IL62SDWJYS110, TP 31
Chicago, IL66HDWGBO (Univision)119, TP 31
Rockford, IL23HDWIFR (CBS)110, TP 29
Rockford, IL39HDWQRF (FOX)110, TP 29
Rockford, IL13HDWREX (NBC)110, TP 29
Rockford, IL60SDPBS110, TP 05
The Boise locals are all on Satellite 119 Transponder 2. Do you need me to list out each local station's callsign?
Nope - I have all the callsigns already. This is exactly what I needed. However, can you confirm that these are the locals that Dish currently has? 8 channels? Sometimes there is a dispute or some random local that Dish doesn't have a contract to carry.
Boise, ID2HDKBOI (CBS)119, TP 02
Boise, ID6HDKIVI (ABC)119, TP 02
Boise, ID7HDKTVB (NBC)119, TP 02
Boise, ID9HDKYUU (CW)119, TP 02
Boise, ID11HDKNIN (FOX)119, TP 02
Boise, ID12HDKTRV (ION)119, TP 02
Boise, ID39HDKKJB119, TP 02
Boise, ID60HDKAID (PBS)119, TP 02
San Francisco, CA
2 - KTVU (FOX) - 119/4
4 - KRON (MYTV) - 119/4
5 - KPIX (CBS) - 119/4
7 - KGO (ABC) - 119/4
8 - KQSL - 119/4
9 - KQED (PBS) -119/4
11 - KNTV (NBC) - 119/4
14 - KDTV (UNIVISION) - 119/4
20 - KOFY -110/31
22 - KRCB (PBS) - 119/6
26 - KTSF - 110/31
36 - KICU - 119/4
38 - KCNS - 119/6
42 - KTNC - 119/6
44 - KBCW (CW) - 119/6
48 - KSTS (TELEMUNDO) - 119/6
50 - KEMO - 119/6
54 - KQEH (PBS) - 119/6
60 - KPJK - 119/6
65 - KKPX (ION) - 119/6
66 - KFSF (UNIMÁS) - 119/4
68 - KTLN (H&I) - 119/4
Yup that looks about right.
For St Louis
St Louis, MO2HDKTVI (FOX)119, TP 11
St Louis, MO4HDKMOV (CBS)119, TP 11
St Louis, MO5HDKSDK (NBC)119, TP 11
St Louis, MO9HDKETC (PBS)119, TP 11
St Louis, MO11HDKPLR (CW)119, TP 11
St Louis, MO13SDKPXS119, TP 11
St Louis, MO24HDKNLC (MeTV)119, TP 11
St Louis, MO30HDKDNL (ABC)119, TP 11
St Louis, MO46HDWRBU (ion)119, TP 11
Reactions: zippyfrog
San Francisco, CA
8 - KQSL - 119/4
20 - KOFY -110/31
26 - KTSF - 110/31
36 - KICU - 119/4
38 - KCNS - 119/6
42 - KTNC - 119/6
50 - KEMO - 119/6
60 - KPJK - 119/6
Thanks! Are all the channels HD except for KTSF?
It's got to be 119, TP 8. 119, TP 17 has 16 national HD channels.
Just to confirm then, these are the locals you have? These 9 channels and they are all in HD?
Portland, OR2HDKATU (ABC)119, TP 08
Portland, OR6HDKOIN (CBS)119, TP 08
Portland, OR8HDKGW (NBC)119, TP 08
Portland, OR10HDKOPB (PBS)119, TP 08
Portland, OR12HDKPTV (FOX)119, TP 08
Portland, OR16HDKUNP (Univision)119, TP 08
Portland, OR22HDKPXG (ION)119, TP 08
Portland, OR32HDKRCW (CW)119, TP 08
Portland, OR49HDKPDX (My Network TV)119, TP 08
Yes, all in HD.
hopper 3 storage
EchoStar / Dish’s Path Forward
