Can you factory reset a Wally if it's never been activated?
Stuart Sweet
Staff member
HERE TO HELP YOU!
Cutting Edge
Apr 22, 2023
1,889
432
Southern California
Folks if you know me at all, you know that I have a long tenure with DIRECTV. But I'm getting more and more into DISH stuff too.
Wondering if anyone can answer the following question: Is it possible to factory-reset or check-switch a Wally BEFORE it is activated? I'm working with a situation where a Wally isn't detecting a Tailgater so it can't activate. If it were activated I understand that doing a check-switch or factory reset would be the next move.
Yes. Pair the remote, then hit the Options Button several times until the Accessory Tool bar shows up. Move all the way to the right and click on that menu button. Then hit home to get to the main menu.
Or you can hit Skip back arrow - recall - skip forward arrow, then home
Hello.
The procedure you suggested did not work for me, is there another way or something else to do a factory reset to a Wally before it is activated?
Thank you.
What exactly happened when you tried?
explosion GIF
The receiver shows the installation summary screen indicating the receiver is not activated.
After I hit the Options Button several times or hit Skip back arrow - recall - skip forward arrow, then home, nothing happens.
The remote is definitely paired to the receiver?
Yes, the remote is paired to the receiver.
In the summary screen there are 3 options: screen resolution, tv remote pairing and receiver activation. I can access the 3 options with the remote but always returns to the summary screen.
In the activation screen, after a while, returns to the summary and keeps showing not activated.
If it's not activated, either it's not getting a signal or the wrong Receiver and/or Smart Card numbers are assigned to the account.
But, if the remote IS paired, skip back - recall - skip back WILL get you out of either of those screens.
The other thing, once you get out of there is in the Check Switch screen (Diagnostics\Dish) on the left where it says Tuner, Satellite and Transponder. Tuner and Transponder will show a 0. Run a check switch and see if it picks up the satellites
Thank you HipKat. As you indicated, the sequence: skip back-recall-skip back worked and I was able to do the reset and switch check.
A note: at first, I wasn't able to get out of the summary screen because I was using the sequence Skip back arrow - recall - skip forward arrow indicated at the top of this post --- a typo, I guess.
And sorry for answer until today.
Thank you.
Satellite Channels Moving to Streaming Only
Sofabaton Remotes - Any success with Dish Hopper control?
