Getting into HAM in 2024?
An elevated vertical using a telescoping vertical element is cheap and efficient. It can be adjusted in length to tune for HF ham bands. You need two tuned radials with the same length as the vertical element. So, for 20m, the vertical and radials need to each be about 16 feet long.
I use this one for remote operation and can install it in minutes. The parts are available on amazon. I just slide the telescoping element a little shorter for higher frequencies and fold back the radials to match.
Reactions: Cham
I live in an apartment these days, and only get on the air to talk to old friends on 2M. I have had good luck using a 5/8 mobile whip in front of a window. I bought a 30" galvanized feed dish at Tractor Supply, and found that it makes a good ground plane for the mobile. No muss, fuss or visibility to the neighbors.
10M has been wide open. Since the beginning of Nov I've made 142 contacts in 60 countries from as far east as Cyprus all the way west (as the sun moves) to Hawaii and as far south as Argentina and Chile and southwest into Oceania as far as Norfolk Island. I'm using an old Icom IC-735 (100 watts) coupled to a simple 20ft vertical.
Upgraded the shack a wee bit. I added a Kenwood TS-570SG to the Icom IC-735 so now have two stations plus I built a Hamclock using a Raspberry Pi 4B.
Funny, I was JUST talking to an old friend of mine about his setup and losing an antenna in the wind last night.
This is HIS setup.
You guys do spend some money....
Reactions: Foxbat
From the pictures getting into HAM radio is too expensive for me
Like everything, there are many ways to enjoy amateur radio. You can build simple wire antennas (dipole, inverted vee, or even a homemade vertical) for low cost. You can buy simple kits and assemble them yourself. Lack of a big budget doesn't need to prevent you from enjoying the hobby.
I was lucky when I got my license. I was gifted some used radio gear and got on the air with very little cost. As time went on and I acquired new radios I donated my older radios to new hams.
Check to see if there is an amateur radio club in your area. Most are open to allowing people who are interested in the hoby to sit in on their meetings and ask questions. You can get on 2 meters or the 70 cm band for less than $100 these days. Yes the fancy HF gear gets expensive. But you don't need fancy to enjoy the hobby.
Everything you see in my pic, and it's a lot of stuff, adds up to considerably less than $1300 so maybe not as expensive as it might look. Best bet for reasonable prices are hamfests and as for an antenna, my 20' vertical that has gotten me confirmed contacts from as far east as Cyprus and as far west as Hawaii cost $110 on Amazon. As mentioned earlier, find a nearby radio club and sit in on a couple of get togethers. Those folks would be more than happy to help get you set up.
Reactions: Foxbat
The largest club in Arkansas has the name of the small town I live in. But the meetings are held in a town 30 minutes away and at night. I can't drive at night.
  • Sad
Reactions: TRG
For the HF bands, all my antennas are homemade dipoles and a couple of end feds for multiple band experimentation using recycled wire. The baluns and ununs and quality coax cable really are only a few hundred dollars. The radios on the other hand is where the expense comes in.
Lately my favorite band has been 10 meters. I hear plenty of CB DX SSB activity in the last year as well. Even though my son and I are both hams we sometimes communicate locally on 11 meters. Last month during one of our evening QSOs we had multiple AM band contacts to Florida, Texas, Kansas and one in California with others that just happened to copy us with 4 watts with a President Thomas and Bill model radios.
Ever hear the guy from Louisiana on 11 meters? He must be running a slipper or something because he comes thru every day like he's right next door, and I'm in PA.
I'm thinking about cobbling a vertical together as I have a bunch of 1" emt conduit and 14 ga wire. Are you guys using a 4:1 un un on your rigs? My tuner has a built in 4:1 balun but that's for ladder line
All of my current HF antennas are home-made (other than the wire itself). Home made baluns and ununs to make things match. Have had some great deals on feedline at hamfests, but I have bought new stuff for UHF etc.
I have found that (for me) it's best to purchase a good mobile VHF/UHF antenna as home-made contraptions are difficult to build to last in the weather and road conditions we drive up here. I often drive in areas that have no cell coverage, so I do spend on good antennas, radios, etc for mobile or portable use.
Think my first FM rig was around $100 used, and first HF rig maybe $200-ish from a ham buddy. Used a home-made J-pole for 2m, and a 1/4 wave piece of electric fence wire for an end-fed tuned for local nets on 80m. Used an old telephone pole for a tower and some pipe for a mast. Eventually added a tuner for HF so I could work other bands. Of course this was 30 years ago.
You can get by really cheap if you look in the right places, and take your time collecting the equipment and knowledge you need.
The good old days! :)
Reactions: Radioguy41
I put up a 1/4 wave vertical for 20m this weekend, just 16 ish feet of 1 inch EMT insulated with 1 1/4" sch 80 pvc pipe stuck in the ground, 4 16 ish ft wire radials across the ground. If it's still there I'll post a picture.....
Just reviving an old thread here. Scott Greczkowski did you eventually get your ham license? It is a hobby that is fun and will give you a lifetime of learning.
I used to be heavily into C-Band, Ku-Band satellite years ago and used to visit this site daily. Life got busy with marriage, kids, etc and I eventually drifted away from satellite. 5 years ago, during the pandemic, I took an online course through our local amateur radio club and got my ham radio license. (Basic with Honours here in Canada, which is closely equivalent to the General license in the USA). Radio has been an almost daily activity for me. I am currently learning morse code to get my morse certification, which doesn't get me much more than the ability to brag that I've got it...
Take Care!
Take Care!
Welcome to the "club". We don't have a morse code requirement in the U.S. anymore. I didn't get all that proficient with it but I did get to 15 WPM but then they dropped the requirement which made it easy for me to get the Extra class license. I have had a radiotelephone license since the early 70s and have been an electronic technician since the 70s also. I don't post my call sign on social media because I'd rather remain anonymous as much as possible.
Reactions: Foxbat
HF setups definitely are expensive. Just a decent HF transceiver will set you back $1500. Then a power supply, tower, HF antenna, concrete, cabling, maybe guy wires, VHF/UHF antennas, etc could get you to $3000+. C-band satellite isn't all that cheap either.
Hi WhiteBeard. Morse code is no longer a requirement here in Canada either, which has opened up the hobby to a lot more people. The ham radio hobby is so huge. Some people are into HF only, some are into digital modes only. Some people in our radio club only use CW (morse code). I love the hobby, because no matter what a person's specific interests are, there is a path they can go down. I've experimented with the analog modes, digital modes, VHF, UHF, HF and wanted to get back to the roots of the hobby and learn morse code. So far so good. I am using the G4FON program in Windows to learn.
73
Reactions: WhiteBeard
Uniden SDS100 and SDS200
Back in the game, with upgrades
