DIRECTV Transponder Map ~ Data 5/07/2025
I overlooked that there are 15 Fast APG PIDs (SCIDs) on TPN 5 for 15 local markets . They are probably not going to convert that TPN to HD. The transponder has been on and off this morning. When up, It has a solid DSS modulated multiplexed digital signal, but there are no audio or video PIDS present. When it is down, there is still a strong DSS QPSK carrier with a SNR of 14.5 dB here in Northern NY. It appears to be fed by random noise. My guess is that they are making changes or repairing equipment in the multiplexors or other equipment in the chain of electronics feeding the uplink transmitter.
I corrected a typo. 15 local markets
DirecTV Satellite Transponder Updates for May 07 2025
Comparison of Transponder Data for May 07 2025 vs Apr 30 2025:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Previously unused Transponder with current APG records::
Net 15 TID 14 Beam NAT is a National Transponder on D12@103ca, TPN 15
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
274​
1447​
SD mpeg4
138​
199​
SD mpeg2
446​
2​
RB​
Audio​
89​
Push​
30​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
38​
4​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
A few new TEST channels
Weekly Analysis soon
Enjoy
DataDigesters
Reactions: lordodogg
Prep to move some channels to D12 TPN 15 (MARQHD, FOXDHD, DSTRHD, fuseHD, CBSeHD and TUDNHD)
9755 OFFER - Paramount+ with Showtime is live
Passing along Gracenote's updates for KCBD, KATB, and KZTV
D8 at 119W has another 10 years of life (2035).
The application for renewal of its license is for 5 years, until August 23, 2030. The application states that it will have enough fuel until 2035, but the FCC wants renewals in 5 year increments, according to the application.
PIP not showing ON Option
