For a permanent "set and forget" installation, there's little difference between the two. But for portable use such as RV'ing and tailgating, there's no contest, the 1K4 is the clear winner for ease of aiming. The down side to the 1K4 is the difficulty in adapting it to use the newer hybrid slimline LNBF's. The DPH42 switch negates the need for that though. The 1K4 is easily adapted to use the 1K2 DPP LNBF's.In my opinion 1k.4 is better cuz its a little easier to aim from my experience...yes I'm taking about the dish 1k.2 and 1k.4
The Vernier adjustment would be nice for mobile use, but DISH decided that the WA version of the 1000.4 was a bad idea, so the 1000.2 is what we use out West.
I'd switch back to a Dish 500 if the appropriate LNB were available.
I did manage to remove the little middle plastic tab on the Y bracket on the 1k4 to fit a 1k2 lnb. It's my main sat and works great too!For a permanent "set and forget" installation, there's little difference between the two. But for portable use such as RV'ing and tailgating, there's no contest, the 1K4 is the clear winner for ease of aiming. The down side to the 1K4 is the difficulty in adapting it to use the newer hybrid slimline LNBF's. The DPH42 switch negates the need for that though. The 1K4 is easily adapted to use the 1K2 DPP LNBF's.
I do have a 500 but converted the dp twin to dpP via a dpp44 switch. The only downside is I donr have a dpH42The Vernier adjustment would be nice for mobile use, but DISH decided that the WA version of the 1000.4 was a bad idea, so the 1000.2 is what we use out West.
This mostly defeats the purpose in this day and age.The only downside is I donr have a dpH42
If you have a 1K4, I wouldn't change anything except to add a DPH42 if you need it for a Hopper 3.I do have a 500 but converted the dp twin to dpP via a dpp44 switch. The only downside is I donr have a dpH42
Mine didn't come with an lnb so I just put a 1k.2 ea head on it..its also hybridIf you have a 1K4, I wouldn't change anything except to add a DPH42 if you need it for a Hopper 3.
... i'll let someone else put it together and set it up
When we were traveling RV'ers, I sometimes set up our tripod mounted 1K4 as often as daily. It became just another 10-15 minute part of our routine site setup. Now that we're streaming everything, I almost miss doing that. Almost...i prefer a t.v. that just turns on and works... i'll let someone else put it together and set it up
I cant stand streaming.When we were traveling RV'ers, I sometimes set up our tripod mounted 1K4 as often as daily. It became just another 10-15 minute part of our routine site setup. Now that we're streaming everything, I almost miss doing that. Almost...
It took us about a month to get comfortable with streaming compared to Dish, but the savings only took a minute to get used to.I cant stand streaming.
I cant have my tv without a DVR system like the vip.It took us about a month to get comfortable with streaming compared to Dish, but the savings only took a minute to get used to.![]()
The YTTV system works fine for the majority of the programming we want to save. We haven't missed our H2's at all this year.I cant have my tv without a DVR system like the vip.
Streaming typically has everything available all the time, and there's no limit on recordings.I cant have my tv without a DVR system like the vip.
