Hopper Plus
Things like youtube and being able to download apps like on a roku
Its me again. I am trying to get my hopper to work without the hopper plus, but I keep getting a "signal not found" message on my tv. My connection before was cable from satellite to hopper 3 w/ sling. USB to hopper plus, hdmi from hopper plus to audio receiver, then hdmi to tv. Right now, I have the connection with satellite cable to hopper plus, then hdmi cable from hopper to tv. (I left out the audio receiver connection in case that was causing a problem too. ). I did get a message that the hopper plus wasns't connected to the hopper and I would need to do that, but then that went blank and now all I get is the signal not found message.
hopefully someone can chime in here as i never had a hopper +... though id'e get rid of it and keep my system simple
My current connected statement above was incorrect. My current connection is cable from satellite to hopper 3, then HDMI from hopper to tv. Took out the hopper plus and audio receiver. Still get signal not found. I did push the reset button on the hopper 3, and have powered off an on by unplugging several times, but so far, no luck. I did manage to convince the Dish folks to send out a technician, but it will be 4 days.
Do this, and follow the instructions exactly. These instructions come from Partysox who is extremely knowledgeable on the subject.
Switch the HDMI cable from the + to the H3 and just unplug the power brick from the +, You don't have to unplug the usb cable. Don't reboot the H3 you will have that blue screen just wait the H3 will reboot on its own it may take 10-15-20 minutes to reboot, after reboot if you get a no signal popup hit guide go to a channel you know enter.
tell the guy you don't want the plus!!! i never had the plus and with all of your problems with it it sounds like i wouldn't want it either
hopefully this saves him from a tech visit!!! then he can call dish and get an RMA to send it back
Will try this! Thanks so much.
buying from dish
