OTA Antenna with amplifier using Dish OTA Module-USB
Jerab
8
9
Texas
I just purchased a digital HDTV antenna model AN4006-001R. This comes with an amplifier that connects to the antenna's coax. The other end of the amplifier has another coax and a usb. I am trying to connect it to my hopper 3 so I can see the OTA channels on my guide. My problem is if I use the included amplifier, I have an extra usb plug since the dish OTA module also has a usb. I tried to connect it without the amplifier and get no channels when I scan. I also tried to connect the coax end of the amplifier to the dish OTA module and just use the dish OTA module usb. The usb from the booster wasn't plugged into anything.
I installed the new antenna with included amplifier attachment directly to my TV and got a lot of OTA channels.
What am I doing wrong?
I'm not sure I understand what you did. Your antenna amplifier needs a usb power source. Either you can plug it into a small power brick like comes with your cellphone, or you can plug it into most television usb ports and get power. The antenna coax must be attached to the DISH OTA module input.
The DISH OTA module must be plugged directly into the DISH receiver usb port.
I agree with above, that's not a good antenna for anything but nearby UHF stations. If you have any VHF stations, you probably won't pick them up well unless you are very close to the station broadcast antenna. But, that's not your immediate issue.
Thank you. I will see if I can plug both USBs into ports. The hopper has 2 usb ports on the back. One is 2.0 and the other is 3.0 I tried plugging them both in, but still got zero on the scans. I don't understand why a bunch of stations are showing if connected to the TV and none if connected to the hopper.
Try plugging in the USB power for the antenna into a separate power source such as a 2 amp cell phone charger.
Just a guess, there could be a chance the hopper does not have enough power on the USB port to power the dongle and antenna. Antenna could be sucking all the power to the point the dongle cannot operate.
Stick a paper clip in the dongle to act as an antenna, and only connect the dongle to the hopper. Depending on the area you may pick up a few channels using this method and this will help you trouble shoot the situation.
Its also possible that the amplifier is introducing too much noise into the signal from the antenna. To be perfectly honest with you the antenna you have is crap, but may work good depending on how close you are to the broadcast towers. Ever since broadcasts went digital, its a known fact that all tuners in TVs and devices such as the Hopper USB dongle have different sensitivity levels when picking up over the air signals.
If anyone remembers the DTV pal, there was 2 different versions of that set top box. The second version or generation of the DTV pal had a better tuner which had the ability to pick up more stations. Its almost like the fact your TV picks up lots of channels. However you should get something on the dongle, the fact you get nothing means you got something going on such as the power.
I think its really crappy that in an effort to save money a lot of these companies are not including USB power adaptors. I get it, but a lot of people do not have good charging devices, For example, I have several google nest cameras A few of my cameras are outdoor and the USB power supply got wet and damaged.
I had a cheap 1 amp charger sitting in my kitchen drawer and used that. Camera lit up but would not work. I had to get a 2 amp charger off amazon the other day to make it work again.
Even though my nest camera came with a charger, point was not everyone is going to have a spare charger laying around that can provide power a device correctly, especially when none of these devices that likely came from China state the power requirements on them
I got tons of channels when I connected it directly to my TV.
Jerab, I think you are making it too difficult. Simply plug the amp USB plug from the antenna to the amplifier block and plug this into a wall outlet. Then plug the RF end of your antenna into the Dish OTA Adapter. Finally, connect the other end of the Dish OTA adapter (USB end) into the Hopper.
I would not connect the amp USB end into the Hopper. As others mentioned, the Hopper may not be able to power the antenna. Only the Dish OTA USB adapter should be plugged into the Hopper.
And then, as others mentioned, you need to go into the Settings on your Hopper and setup and scan for OTA channels.
It seems to be a good antenna. I got tons of channels when I connected it directly to my TV. I hope to find a way to connect it to my hopper 3.
Get you a splitter and plug your antenna into it as a source and then one goes to the TV and one to the DISH ota tuner that hooks into the hopper by usb.
I use a Televes Diginova Boss antenna that has a powered splitter that plugs into the wall and I have it connected to all my different devices. The actual antenna hooks up to the outside and was easy to install on my old sat J pipe on the eave of the house. Got it off Amazon for like $85.00 back about two years ago. OF course now it is $129.00 because of tariffs. Just type in the name of the antenna and it come up. This is the same antenna DISH used to install for Air TV installs used with the Sling TV app. It works about 25 to 30 miles from the towers.
It a low-profile , outdoor HD TV antenna designed for discreet installation where aesthetics matter. It features a built-in , self adusting amplifier ( Boss technology) that optimizes signal levels automatically and filters out celllar interference. This antenna is ready for digital TV recepton including telescopic VHF antenna for improved reception of lower channels as well as UHF channels.
Intelligent amplification: The built in amplifier with Boss technology automatically adjusts it gain to prevent overloading from strong signals and under-amplification of weak ones ensuring a stable signal.
Compact and low-profile design: The antenna is enclosed in a weatherproof radome, making it suitable for building fronts, balconies, and other visible locations.
Telescopic VHF antenna: For difficult reception conditions , you can extend the telescoping antennas to improve reception of low-band VHF channels.
Passive operation: When powered off the antenna's electronics are bypassed and it continues to work in passive mode ,so you won't lose your TV signal during power outage.
Complete kit: It typically comes with all the necessary parts for mounting such as a mast bracket and a 12v power supply.
I also use a DTV antenna app on my phone that lets me lock in on my affiliates and point the antenna where it needs to point. Makes it easy to find all my channels. Mine are all in the same general area, both UHF and VHF.
AN outdoor antenna is much better than a dounut!!! we have a winegard elite 360 pro that works wonders it has the app and everything. and as asked before are you using the hopper to scan for channels 🤔
i think dish will install an outdoor antenna as well for a fee. i don't know what it includes as we had our own antenna at the time of install. we tipped our installers nicely!!! they took care of everything...
EchoStar / Dish’s Path Forward
