Directv Gemini Receiver - C71KWX Question
mitchellga
8
Florida
I am currently a Directv Stream customer.using the Directv Gemini Box when it was branded AT&T. When I go into my account to add more devices, although it shows the AT&T box as my equipment, it is just allowing me the option to add the Gemini Air. Does anyone know if I buy the C71KWX from another source such as Solid Signal if it will work either hardwired to the Internet or wirelessly? Thanks!
I believe your account only lists devices you got from AT&T/DIRECTV. You can add as many more devices as you please and you don't need to add them into your account. Just login with your username and password and follow the setup instructions. There are no extra charges for 3rd party devices including the Gemini Air.
Yes, You're right about what my account lists. My concern is whether the Gemini box will work vs the Gemini Air.
Yes they both work with the streaming service.
So will this work even though it says satellite dish required. It's sold by Solid Signal
If you acquire a C71KW-400 that has been configured for use as a Satellite client, you need to reset it to factory settings by holding the red button down for at least 20 seconds.
I am not sure if you get a satellite Gemini if a factory reset will return it to streaming status. You can get the streaming boxes cheaper from either Walmart or eBay. Just make sure the eBay seller has a good return policy just in case. This seller on eBay has a good reputation.
Price is $41.99 for a Gemini device at that site.
Thank you!
I have never done that, so I can't say for sure. I did once reset a satellite configured C71K-400 while totally disconnected, configured it for Wi-Fi, and it seemed to be trying to set up for DirecTV Stream. The may have updated the firmware so that doesn't happen anymore.
The Solid Signal listing is inaccurately calling this a satellite receiver when it has no satellite tuners in it. It would require more than a satellite dish, specifically it would need a DirecTV Genie server (HR44, HR54 or HS17) AND a satellite dish to be used as a Satellite client. But I don;t understand why you would pay $219, for one of these when the former Osprey boxes are available much cheaper all over the Internet.
DirecTV Stream is trying to get their customers on the Gemini Air. If I were a Stream customer looking to add another box, I would be looking for a deal on a Gemini Air.
Reactions: lordodogg
Do people still watch satellite TV these days
