DIRECTV Transponder Map ~ Data 1/28/2026
Tvanswerman.com said new mix channels coming next week
Those are app only and already mentioned in the Mix channels thread.
Cowboy Channel HD is testing
Is this just on sat, or is it already (in HD) on stream?
Also a little OT curiosity...is Cowboy Ch doing "pay-to-play" now for some reason, as all of a sudden it's been popping up on other providers like FiOS, & notably Comcast (though in SD-only o_O ) which has steadfastly refused to carry it's parent channel RFD-TV since the channel started.
Cowboy Channel has been testing on stream for about a month
The HD feed appeared in the sat APG data this week, although right now it's just mapped to the Ka offline slate.
As of now it's not pay to play, which is why it's Ultimate+ on sat. The pay to play channels like Racer and Pursuit are in all English, Spanish and international base packages.
The Peacock Games channels should be going live next week:
12/9 NCAAM Illinois at Ohio State (Games1)
12/13 Liverpool vs. Brighton & Hove Albion (Games1)
12/13 NCAAM Marquette at Purdue (Games2)
12/14 Crystal Palace vs. Manchester City (Games1)
DirecTV Satellite Transponder Updates for Dec 10 2025
Comparison of Transponder Data for Dec 10 2025 vs Dec 03 2025:
No changes in system tables for any transponder tuning parameters.
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
274​
1​
1448​
1​
SD mpeg4
142​
196​
-1​
SD mpeg2
444​
RB​
Audio​
89​
Push​
25​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
39​
-1​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
A few Music channel changes
Several LIL name changes
Weekly Update soon
Enjoy
DataDigesters
Reactions: lordodogg
In additon to all the Sinclair shuffles, Sounds of the Season Ultra, Cowboy HD and Peacock Games going live in the past week,
9752 GIFT ($5.99 movie rental on us) is now live
Puerto Rico's 179 Punto2 is now in HD
I just checked out what has happened to my local Sinclair owned stations in the Greenville-New Bern-Washington, NC DMA (known locally as Eastern North Carolina or ENC). I have an LCC, so I also get OTA signals in my DirecTV Guide. I can see and tune to the local FOX station on Satellite on channel 14, listed as WCTI-D2. I can tune to it OTA on 12-2 and 14-1 (WYDODT). I wonder how long that will be duplicated? I reran the OTA setup to see if there would be any changes, but there were none. After a rescan, my TV OTA tuner lists 12.2 as FOX and 14.1 as WYDO-DT, but they are carrying the same programming.
Both transmitters are on the same tower.
When I use over the air on tv they have
12.2 as Fox (same as 14.2)
14.1 still Fox also
14.1 WYDODT in Greenville and 39.1 WEMTDT in the Tri-Cities will be switching to ROAR in mid-January.
The rest of the affected stations already switched to ROAR, and in a few cases DTV ended up carrying ROAR for a few minutes before they reconfigured the tuners at the local receive facilities.
Moving from satellite to streaming in 2026
