What does "internet protected " mean in this context.My locals are not internet protected. Is that just a local market thing or national?
It means that your locals do not switch automatically to internet download if the satellite signal is lost.What does "internet protected " mean in this context.
There are a ton of "Bonus Channels" available that require an internet connection (90 through 98). Also there are many streaming only channels that require same.Another question related to this subject...
If (actually, I do) I stream with smart tv apps and external devices why should I keep Hopper connected to my modem?
The guide is downloaded with satellite and I don't use dish anywhere app when I travel to upload shows (saved in Hopper) to view them somewhere.
Is there any advantage having an Internet connection?
Yes, the DISH logo when first tuned to the channel would show the streaming but in my case, I never have the box in standby so it's already tuned in to the channel for at least a few hours after the nightly reboot.While the stream is downloading the first indication is that you see momentarily is the round red wifi symbol if your H3 is connected via wifi. Ethernet connection, I don't know but it still has to load enough data to build the video frames which takes a couple of seconds, whereas satellite is usually much quicker.
All in all It really does not matter.as long as you get your programming.
If you are lucky enough to get your locals on an antenna.It means that your locals do not switch automatically to internet download if the satellite signal is lost.
You have to have an OTA dongle hooked to an antenna and change the channel on the receiver to the OTA channel yourself.
Yep, didn't try it on a non-streaming channel but basically Recall on a streaming channel would not respond with a pop-up.If it doesn't show a Satellite, you're streaming
