Has anyone experienced this problem and/or know what might be the cause.
I have a 622 and Dish 1000. There is one twin LNB and one single LNB. Two or three weeks ago I started experiencing spotty reception where it goes to the searching for satellite screen time after time and every so often the check switch screen comes on. The interesting thing is this only happens on one TV (most often TV1). For example, if the same channel is on on TV1 and TV2 in dual mode, only one of the TVs loses signal. It is also intermittent, in that it can go for a day with no problems then start doing it again. It seems to affect satellites 110 and 129 but not 119, but that could be just the channels I watch more often. Dish sent out a service tech last Saturday who told me that one of the LNBs felt too warm so he changed it out. He also commented on the RG-59 cable that Dish tied into when I replaced Cable with Dish a couple of years ago. He also pointed out a tree that he said could be blocking the view of the satellite. (If the tree is a problem, how do you explain that TV2 can be working perfectly while TV1 is searching for a satellite while watching the same channel.)
I had similar problems when I first replaced my 942 with a 622 earlier this year. The Check Switch screen over and over again. A tech came out and replaced LNBs and some connectors but that didn't fix the problem. A new 622 was sent to me and that worked well for months until the recent problems.
Anyway, everything went well for a day or so after the Tech left on Saturday, then the problem started happening again so changing out the LNB wasn't the answer. Any thoughts?
