Uplink Activity Report - 12/01/2006
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
104,396
31,536
Newington, CT
The SatelliteGuys.US Uplink Activity Report - 12/01/2006 - 44 changes
Uplink Comparison Range: 11/30/2006 07:52P - 12/01/2006 07:01A - (GMT-05:00) Eastern Time (US & Canada)
103 - ONPPV removed from EchoStar7 119W TP 16 ConUS beam
210 - CSPAN moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A)
212 - CSPN2 moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 08 ConUS beam (A)
222 - HSN moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
226 - QVC moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
228 - SHNBC moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A)
242 - NBC-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
244 - CBS-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
246 - ABC-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
248 - FOX-W moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
299 - REELZ moved from EchoStar7 119W TP 11 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
500 - ONPPV removed from EchoStar7 119W TP 16 ConUS beam
505 - PPV removed from EchoStar7 119W TP 16 ConUS beam
509 - PPV removed from EchoStar7 119W TP 17 ConUS beam
6200 - WJLA removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6201 - WUSA removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6202 - WRC removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6203 - KTBS removed from EchoStar10 110W TP 27 Spotbeam 15 from New Braunfels
6204 - KMSS removed from EchoStar10 110W TP 27 Spotbeam 15 from New Braunfels
6205 - KSAT removed from EchoStar10 110W TP 23 Spotbeam 22 from New Braunfels
6206 - KENS removed from EchoStar10 110W TP 23 Spotbeam 22 from New Braunfels
6208 - WRTV removed from EchoStar10 110W TP 18 Spotbeam 13 from Monee
6209 - WTHR removed from EchoStar10 110W TP 18 Spotbeam 13 from Monee
6211 - WCTV removed from EchoStar10 110W TP 25 Spotbeam 03 from Mount Jackson
6217 - WAPT removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6218 - WJTV removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6219 - WLBT removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6220 - WUFX removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6221 - WDBD removed from EchoStar10 110W TP 26 Spotbeam 11 from New Braunfels
6226 - WDBJ removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6227 - WSLS removed from EchoStar10 110W TP 25 Spotbeam 05 from Mount Jackson
6233 - WMUR removed from EchoStar10 110W TP 26 Spotbeam 04 from Mount Jackson
6234 - WMUR removed from EchoStar10 110W TP 26 Spotbeam 04 from Mount Jackson
6235 - WFMY removed from EchoStar10 110W TP 31 Spotbeam 05 from Mount Jackson
6236 - WXII removed from EchoStar10 110W TP 31 Spotbeam 05 from Mount Jackson
7658 - KRIV removed from EchoStar10 110W TP 29 Spotbeam 17 from New Braunfels
7926 - WTVY removed from EchoStar10 110W TP 04 Spotbeam 07 from New Braunfels
8000 - KABC moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8001 - KCBS moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8002 - KNBC moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
8003 - KTTV moved from EchoStar7 119W TP 15 ConUS beam to EchoStar7 119W TP 11 ConUS beam (A)
19046 - ESFFL removed from EchoStar7 119W TP 04 ConUS beam
19064 - FFTV removed from EchoStar7 119W TP 04 ConUS beam
19067 - ESPNI removed from EchoStar7 119W TP 04 ConUS beam
Channels in the system: 3152
(A) = Available
(NA) = Not Available
Didn't digiblur already post that activity last night?
Yes, but technically it was 12/1/06 activity for the eastern time zone ;)
The way my custom uplink report utility works is, it compares 2 snapshots of E*'s DVB tables. Scott had taken a snapshot earlier in the day. I covered the uplink reports last night while Scott was sleeping from a crazy day. Scott simply posted the report from his snapshot differences between Thursday and Friday AM.
I predict some descriptor flags getting flipped to 01 01 23 28.... tonight at 11pm central time.
A few of those, but there should be more just changing and some channels just disappearing.
Now that I think about it, there may not be many of those you list. Those people in Denver, Chicago, New York City and Los Angeles would not take kindly to that. :)
I predict it should be 02 01 xx xx; must be first part changed - ie ProviderID, not groupID. Khmm, NPS must have OWN ID.
Nothing so drastic as that. NPS already has their code.
We are talking about disabling DiSH Network Distant Codes without disabling Dish Network Local codes.
I know what you mean and it is contained in the same descriptior tag. A hint would be there does not appear to be even one channel in the entire SDT which has a different provider code than the rest. :)
SkyAngel doesn't have their own Provider ID.
Adding another provider ID would take sometime as all of the cards would need to be updated to unencrypt this new provider ID. The alpha and beta testing would take up a good chunk of time. This is kinda the same thing as the 09 04 provider ID Bell ExpressVU uses on the NFL channels on the weekends.
Dish Has ‘Free Speech TV’ Problem
caller id problems
