Hi,
I have a 942 HD Dish receiver with a DPP Twin LNBF and Dish 500. In the past several weeks I have experienced intermittent signal losses. The receiver would show the screen "acquiring satellite signal" for about 20 or 30 seconds, usually not moving from step 0 of 5, then go back to show the satellite channel for a few seconds (only with a black screen), then reverse to the acquiring signal screen.
Check switch reports that everything is OK on both tuners and satellites.
"Point dish" screen (Menu => 611) shows signal locked for tuner 1 only if I select a transponder with odd numbers (e.g., 13, 15, etc.), and no lock if I select a transponder with even numbers. On tuner 2, the reverse occurs: lock on even, no lock on odd.
Dish tech support says that an intermittent signal loss like this can only be caused by bad cables or a failure of the receiver, in which case they say I need to replace the receiver. My local technician dropped a new cable from the dish to the separator, replaced the separator and changed the two cables that go from the separator to the receiver's two tuners. The intermittent signal loss continues.
Before I undertake a major hardware replacement or upgrade I would like the opinion of the tech gurus in this forum as of the accuracy of the diagnosis and fixes recommended. Are there any other possible causes for my problem?
Thank you in advance for your help,
Gianfranco
Gianfranco
to SatelliteGuys.
