switching from legacy to DPP
activ8
59
I need some help in figuring out what I need !
currently this is what I run
Dish 500 110/119
Dish 300 61.5
SW 64
connected to a dual tuner 522 with two lines a 510 /w one line and a 300 one line
a-l-l my stuff is legacy
What I want to do is this:
DISH 1000.2 aimed at 128 ,110 & 119
DISH 500 aimed at 61.5
622 one line from switch with separator
522 one line from switch with separator
510 in from switch
I need to buy the 1000.2 & 622
What LNB's do I need ? I read numerous pdf's but get lost !!
Thanks !
Activ8
The 1000.2 comes with the triple LNB. It also has a satellite input for a 4th satellite location. So you'll need a DP Dual lnb for 61.5, the dish 1000.2 and the 622 receiver. The 1000.2 will feed up to three receivers and it only needs a single cable for dual tuners.
So I don't need a switch ?
No Sir. The 1000.2 can feed up to 3 receivers so you don't need a switch. It has a built in switch for 4 satellites inputs and 3 outputs.
Edit: Make sure the lnb you get for 61.5 is a DP Dual. If you put a Legacy lnb it won't work.
