Pansat 9000 HD + 4:2:2 Coming soon
He was talking about 8psk Trellis that requires large reflector to get lock.
I have not seen any of the consumer receivers support 8psk Trellis and I doubt there will be one.
What you see 8psk listed on the specs of some new comming HDTV receiver is either 8psk Turbo or 8psk DVB-s2.
It will be interesting if manufacture supports 8psk turbo because Dish Network is the only player in N.America who uses this. Consider as an extra thing for hacker-wanna-be. 8psk turbo is not used for DSNG, transmiting content from point A to point B in N.America.
Why would you need a 14' dish for G3, G4 or AMC1?
Bad news
Hello
4:2:2 has been deleted from the specs...
I read they have problem with that and it shouldn't be there
Labgate
Reading the specs...
• Multi Satellite Scan = ? (It will have blind scan or not?)
multi satellite scan isnt blind scan. Just allows you to scan multiple satellites in a row.
the other options are standard on Pansat's
What must the user provide for a "multiscan"?
Is it necessary to input the frequency of each transponder?
Is it necessary to also input the symbol rate of each transponder?
What exactly is the difference between blind and multi?
Thanks.
setup issues
Uncommitted, committed, VBox II, and Pansat 3500SD question
