I can not hold the signal of A&E HD. I get a better signal strength if I go to pointdish, and manually change the transponder to 31, but it keeps defaulting to 27 and won't hold the channel?
What am I doing wrong?
Where are you located??
Thats amazing, considering in 1997 they could bairly squeeze 8 Standard definition channels per transponder!
 . Probably better than the current SD PQ.
. Probably better than the current SD PQ.Encoder hardware power has increased significantly over the last 10 years. Gotta wonder how long they can keep it up. I wonder what the PQ was like on those 8 SD channels though. Probably better than the current SD PQ.
It's not actually on, even for Dish Network Engineers.If I was a Dish Network Engineer I would be watching CH. 379 CSNCH-HD, Then I would flip the switch to share the wealth. PLEASE TURN ON CH. 379 And share the wealth!
Back to the original topic, there are major issues with 129W TP27. When Dish added the HD sports channels, they decreased the quality on the 3 existing HD channels (MAXHD, A&E, and Universal HD). Apparently they set the minimum bitrate for the sports channesl to 4Mbps. Unfortunately, this really hurts when there is no game playing and all the channel is showing is the "DishHD" logo. As you can see from the graph I have attached, no channel dips below 4Mbps.
There are 6 actual video pids on this transponder (even though there are 7 listed on that graph). If you notice, Altud and 5793 HDSKD are graphed the same (green and purple) because they are mapped to the same video pid. When I captured this data there was a DishHD slate on 5791 and 5792. These two channels are eating up 8+Mbps from this mux!!!! That is approx 20% of the mux devoted to DishHD slates!
It is also obvious that they have a 14Mbps rate cap on each individual channel. Keep in mind all 6 video pids are h.264 so we can't really relate to mpeg2 bitrates. The chart captured the real time bitrates of the pids on that mux for approx 1 minute.
Wow!! excellent graph!! I wish I knew what the heck I was looking at!!! So are you are saying that Dish added a sports channel and 129/27 took a dump? Which channel and when?
Sorry for my ignorance, I have no idea WTF a PID and a MUX are. I need to do more research!
Do you have that graph for say a 24 hour period? I've noticed the bulk of my signal loss is an afternoon event.
 . If you look at my graph from 61.5, you'll notice max-hd peaks out much more than on 129. The nulls on the 61.5 tp make me think they are planning for 6 channels on that mux as well.
. If you look at my graph from 61.5, you'll notice max-hd peaks out much more than on 129. The nulls on the 61.5 tp make me think they are planning for 6 channels on that mux as well. .
.its probably the best solution until they send another bird to cover 129w.
Who do you mean by "they" ? ANd what are you referring to as "do that" ?Will they ever do that? What's the current plan?
There are these things called "nouns"...
