Local Channels No Longer On Chan's 2, 4, 5, etc.
DishaDeeYay
4
I used to get my local channels on both the 2-13 range and a range in the 8100's. Now only the 8100 range is working and when I try to put on channel 2 (for example) it goes to channel 84 (HSN). Any idea what happened and how I can fix it?
I called a CSR and they said to do a front panel reset. Didn't work. Removed the card, didn't work.
I AM getting my channels on the higher channel numbers... but I'm more nervous about losing them altogether at some point... if you can read between the lines.
Iceberg: Receiver 301.
KAB: For certain reasons I want to try to solve this without calling Tech Support.
Hall: Favorite List is just "All Chan".
make sure your receiver is not set up to tune off air broadcasts. this will cause the channels from 2-99 to be held for cable/antenna tuning. but if you don't add any off-air locals, then the tuner should stick your locals on the right channels for your market. of course, not all tuners even have the off-air ability.
