3 to 5 LNB install
rupert
74
Slaughter, LA
I currently have a 3LNB installed on the eave (facia board) of my house. Is there any reason why a 5 LNB can't be mounted in the same place? Is it that much bigger or heavier? Can I use support brackets screwed into the roof?
vurbano
On Double Secret Probation
23,815
104
Newport News, VA
It is much heavier mine had to go on top of a small storage room attached to the house.
Brewer4
4,022
Hartford Connecticut
:welcome
Its much heavier and because of the weight and size, it needs a tripod mount and the most solid and stable area. Roofs tend to be the ideal place. Because the 3 LNB and 5 LNB are much different, you can't use the same pole or mounts. Are you installing or Directv?
rupert
74
Slaughter, LA
Dtv is installing. I found that many agree that it's much bigger and heavier, and facia board won't do. I'm thinking of scabbing a piece of board (probably a 2x8) across the truss beams or putting a pole in the ground that would be braced up top by the eave.
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
32,797
17,739
Cheshire CT
Your second option is a good one, as long as the support on the fascia lags into the end of the rafter, not just the fascia.
iwc5893
2,178
The desert of WA, zip code EIEIO
There are other mounting options also. D* recently came out with an S-tube mount for the 5 LNB dish that is designed to be mounted on the corner of the house and does not need any brace poles. Your installer may have one on his truck if you ask and this is a viable option for you.
I've done 4 of these mounts and it is now my favorite way to do 5 LNB dishes. No braces poles, sturdier than hell (I can hang off the mounting tube), installs in less than half the time, and is easier for the sub to remove snow/ice from the dish.
iwc5893
2,178
