10/01/2015 12:25 - Uplink Report - 76 Changes
Uplink PC
Uplink Report PC
May 31, 2014
707
6
SatelliteGuys.US DishNetwork Uplink Report - 10/01/2015 12:25 - 76 Changes
Uplink Comparison Range: 10/01/2015 12:19 - 10/01/2015 12:25 (PST)
MAP Changed:
4971(14) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4971(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4972(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4972(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4973(25) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (25) removed (Dish Network Information Channel)(NA)(H)
4973(25) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (25) removed (Dish Network Information Channel)(NA)(H)
4974(3) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4974(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4975(13) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4975(13) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4976(8) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4976(8) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4977(3) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4977(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4978(37) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (37) removed (Dish Network Information Channel)(NA)(H)
4978(37) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (37) removed (Dish Network Information Channel)(NA)(H)
4979(4) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4979(4) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4980(20) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4980(20) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4981(4) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4981(4) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4982(9) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4982(9) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4983(10) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4983(10) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4984(14) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4984(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4985(3) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4985(3) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4986(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4986(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4987(13) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4987(13) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (13) removed (Dish Network Information Channel)(NA)(H)
4988(11) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4988(11) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4989(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4989(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4990(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4990(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4991(14) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4991(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4992(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4992(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4993(5) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4993(5) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4994(14) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4994(14) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4995(11) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4995(11) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4996(9) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4996(9) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4997(7) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4997(7) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4998(11) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4998(11) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
4999(6) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4999(6) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5000(6) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5000(6) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5001(5) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
5001(5) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
5002(6) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5002(6) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
5003(11) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
5003(11) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (11) removed (Dish Network Information Channel)(NA)(H)
5004(12) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
5004(12) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
5005(8) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
5005(8) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
5006(20) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
5006(20) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
5007(7) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
5007(7) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
5008(10) - DISH [MPEG2 SD] EchoStar14 119W TP 21 ConUS changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
5008(10) - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
Channels in the system: 9764
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
Tampa8
Supporting Founder - I'll stand up and say so
18,299
8,144
Tampa/Eastern Ct
No exactly, 8 day extension both sides cited the Hurricane as one reason.
Peter Parker
Formerly Geronimo
12,397
2,150
I suspect that the hurricane is justa convenient way to stand down without looking like you are caving in. I hope they reach an agreement soon.
9/30/2015 21:51 - Uplink Report - 2 Changes
10/04/2015 19:31 - Uplink Report - 6 Changes
