100mm200mm VESA adapter plates
navychop
Stop overfishing Panthalassa!
63,998
33,365
Northern VA
I removed a 24" Insignia TV from my RV, due to poor viewing angles from below. The TV was mounted on a sliding mount, quite sturdy, but it had no way of pivoting up and down. So I gave it to my in-laws, and mounted it for them on a wall using a mount that pivots in every direction.
I've bought (unopened, can be returned) a 32" Sharp that was on a great sale at Costco. It has superb viewing angles, even from below. It will fit in the area the old TV fit. The old TV weighed 20-25 lbs, the new one, 30-35 lbs.
PROBLEM: The mount has the VESA 100mm x 100mm hole pattern, and the Sharp has 200mm x 200mm. I called the Costco help line, and the guy said "Sure, there's adapters - probably in any Radio Shack." Well, I couldn't see him, but I know his lips were moving, and we all know what that means.
I could get some sheet steel and drill 8 holes and bolt away. I'd rather get something ready made for the purpose. After some searching, I've come up with 3 possibilities:
This one is actually from RS, and weighs 7 lbs. But, as it's meant for wall mounting, I'm not sure it's strong enough to be held by 4 bolts thru the 100mm mount.
This one is just a simple flat panel, which "might" work.
And this one [ame="http://www.amazon.com/Vantage-Point-AX2WL01B-Mount-100mm/dp/B00081I788"]. [/ame] from Amazon appears sturdier, but really wasn't intended for this use, and would require particularly long bolts.
What do you guys think? I'm open to any suggestions. Think I should just get a smaller TV?
SOLD! :p Thanks. Looks like something I can use.
BTW, we all know LCDs should not be laid on their sides. The boxes are so marked. Yet Costco had several laying on their sides. Got one that was upright. That doesn't mean it was always upright. I'll go ahead and open it and test it, now that I have a mounting solution.
Thank you again.
Which one?
TV-a-day Giveaway during March at Newegg
