102 minutes that changed...
cparker
1,461
7
Sanborn, NY
History Channel ... can't record this?
It's on a 9pm here ,,,, can't set it to DVR record either the SD or HD History chanel at 9pm. No error, no message, just does absolutely nothing when I press record with this highlighted in the guide. Other channels either side of it work fine.
Did I miss a memo?
yeah not sure what was going on. "Did you try pressing select when highlighted?" ... uh... yeah.
The channels above and below would record fine by doing exactly that. Only History Channel was acting that way. I did as suggested and just set a timer manually and it worked. Very odd.
System seems otherwise fine this morning
Check your recordings and see if it conflicts with other scheduled recordings. If so it won't record. You may have to delete another scheduled recording first.
Glad you were able to record it. I thought 102 Minutes That Changed America was absolutely incredible.
722 locked up last night, now 200 hours of programming is gone.
How do you scroll Dish Remote Grid
