12/8/2011 3:31am - Uplink Activity Report - 67 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 12/8/2011 3:31am - 67 changes
Uplink Comparison Range: 12/08/2011 03:16A - 12/08/2011 03:31A
Channel Additions:
6220 - WTAE [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (Pittsburgh, PA)(A) (H)
6221 - KDKA [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (Pittsburgh, PA)(A) (H)
6222 - WPXI [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (Pittsburgh, PA)(A) (H)
6223 - WPGH [MPEG4 HD] added to EchoStar8 77W TP 02 ConUS beam (Pittsburgh, PA)(A) (H)
6830 - ANTPR [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
6831 - TVBSL [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
6832 - RBTI [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero)) (A) (H)
6833 - SPRTV [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
6834 - RELIG [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
6835 - SIC [MPEG2 SD] added to EchoStar15 61.5W TP 29 ConUS beam (A) (H)
6836 - KINOE [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
Channel Removals:
589 - ANTPR (A) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
597 - TVBSL (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
598 - RBTI (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero))
609 - SPRTV (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
737 - KINOE (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
767 - RELIG (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
817 - SIC (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 29 ConUS beam
6808 - UP9 (NA) [MPEG2 SD] removed from EchoStar15 61.5W TP 20 ConUS beam (Virtual Channel)
6822 - UP5 (NA) [MPEG4 HD] removed from EchoStar15 61.5W TP 27 ConUS beam (Virtual Channel)
Channel Moves:
8873 - WJAN [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:West Palm Beach, FL-Miami, FL-IND) (A) (H)
5280 - WGXAD [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A) (A) (H)
5281 - WMAZ [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Macon, GA-CBS) (A) (H)
5282 - WMGT [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Macon, GA-NBC) (A) (H)
5283 - WGXA [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX) (A) (H)
5284 - WMUM [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Cochran, GA-PBS) (A) (H)
7881 - WGNM [MPEG4 SD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Macon, GA-IND) (A) (H)
7883 - WPGA [MPEG4 SD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Mkt:Macon, GA-Perry, GA-ABC) (A) (H)
5273 - WTVW [MPEG4 HD] moved from EchoStar8 77W TP 18 ConUS beam to EchoStar8 77W TP 30 ConUS beam (Mkt:Evansville, IN-Evansville, IN-FOX) (A) (H)
5276 - WEVVD [MPEG4 HD] moved from EchoStar8 77W TP 30 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-N/A) (A) (H)
5280 - KAQY [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-Columbia, LA-ABC) (A) (H)
5281 - KNOE [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-Monroe, LA-CBS) (A) (H)
5282 - KTVE [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-NBC) (A) (H)
5283 - KARD [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-FOX) (A) (H)
5284 - KLTM [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-Monroe, LA-PBS) (A) (H)
5285 - KETZ [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-PBS) (A) (H)
7815 - KMCT [MPEG4 SD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar15 61.5W TP 22 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-IND) (A) (H)
6477 - WTAE [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-ABC) (A) (H)
6478 - KDKA [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-CBS) (A) (H)
6479 - WPXI [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-NBC) (A) (H)
6480 - WPGH [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-FOX) (A) (H)
6482 - WPCW [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Jeannette, PA-CW) (A) (H)
6483 - WQED [MPEG4 HD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-PBS) (A) (H)
8134 - WPMY [MPEG4 SD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-MY) (A) (H)
8137 - WPCB [MPEG4 SD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA-Greensburg, PA-REL) (A) (H)
8142 - WINP [MPEG4 SD] moved from EchoStar8 77W TP 02 ConUS beam to EchoStar15 61.5W TP 20 ConUS beam (Mkt:Pittsburgh, PA) (A) (H)
8408 - KUVN [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 16 to Echostar12 61.5W TP 01 Spotbeam 16 (Mkt:Dallas, TX-Fort Worth, TX-N/A) (A) (H)
8409 - KFWD [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 16 to Echostar12 61.5W TP 01 Spotbeam 16 (Mkt:Dallas, TX-Fort Worth, TX-N/A) (A) (H)
8377 - KYAZ [MPEG4 SD] moved from Echostar12 61.5W TP 13 Spotbeam 17 to Echostar12 61.5W TP 09 Spotbeam 17 (Mkt:Houston, TX) (A) (H)
8386 - KETH [MPEG4 SD] moved from Echostar12 61.5W TP 13 Spotbeam 17 to Echostar12 61.5W TP 09 Spotbeam 17 (Mkt:Houston, TX-Houston, TX-TRIN) (A) (H)
5200 - WCHS [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Charleston, WV-ABC) (A) (H)
5201 - WOWK [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Huntington, WV-CBS) (A) (H)
5202 - WSAZ [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Huntington, WV-NBC) (A) (H)
5203 - WVAH [MPEG4 HD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Charleston, WV-FOX) (A) (H)
7319 - WQCW [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-CW) (A) (H)
7321 - WPBY [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Huntington, WV-PBS) (A) (H)
7322 - WOUB [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Athens, OH-PBS) (A) (H)
7325 - WPBO [MPEG4 SD] moved from EchoStar8 77W TP 08 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-PBS) (A) (H)
471 - SPORT [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (Pay Per View Sports & Events) (A)
605 - ANTEN [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (Antenna Satellite (Greek)) (A)
640 - TVJPN [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (TV Japan SAP) (A)
814 - GLOBO [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (TV Globo Internacional) (A) (H)
815 - RCORD [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (Rede Record Internacional (Brasilero)) (A) (H)
911 - ANTRA [MPEG AUDIO] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (ANT1 97.2 FM) (A) (H)
9620 - BTV [MPEG2 SD] moved from EchoStar15 61.5W TP 08 ConUS beam to EchoStar15 61.5W TP 29 ConUS beam (Business TV) (A)
Transponder Changes:
EchoStar15 61.5W TP 22 ConUS beam 21500 8PSK 2/3 added
EchoStar15 61.5W TP 26 ConUS beam 21500 8PSK 2/3 added
Channels in the system: 8375
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v11.10.31
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
dare2be
SatelliteGuys God
12,743
7,776
FL
Why the duplicate Pittsburgh market channels, with the originals being moved to 61.5W?
Mr Tony
3,892
16,982
Mankato, MN
Are they moving locals off the 77?
possibly
With the new EA Twin LNB out it would be easier for folks to have 61.5 & 72 without the need for 77. Why require another slot just for your HD locals when nothing else is on it? (unlike 129 where CONUS HD is on there too)
dare2be
SatelliteGuys God
12,743
7,776
FL
But I still don't understand why new Pittsburgh locals were added to 77W when the existing ones were moved from 77W to 61.5W
TNGTony
Unashamed Bengal Fan
Sep 7, 2003
10,041
803
Cincinnati, Ohio, USA
My guess is the ones at 77 are nothing more than slates telling people that the locals moved to 61.5. Most people wouldn't notice unless they don't have a dish at 61.5.
dare2be
SatelliteGuys God
12,743
7,776
FL
Well, I noticed this morning I had a timer that showed up on both channels (61.5 and 77), plus the mapdown.
Mr Tony
3,892
16,982
Mankato, MN
yep there are some folks when their locals were added to 77W Dish installed a single dish at 77 and tied it into the WA dish they had so they would have 77/110/119/129
This would get them on EA fully
GreginWV
Sep 21, 2008
7
yep there are some folks when their locals were added to 77W Dish installed a single dish at 77 and tied it into the WA dish they had so they would have 77/110/119/129 This would get them on EA fully
It looks like I am one of these folks. My locals are from Charleston WV. I tuned in this morning to the locals,and only received SD channels. I have a single dish pointed at 77, I assume I can just move it around to 61.5. Greg
Stargazer
16,568
340
Western WV
A timer did not fire on my locals last night. I guess this was the reason. It looks like they moved the locals from 77 to 61 to 77 back to 61? I have a wing dish pointed at 77 with my other channels coming off of 110/119/129 because I have a 522 and 722. I have to have the wing dish for my local HD channels. Now I don't know if I should repoint my dish from 77 to 61 or not. I noticed that my local channels were coming in tonight but a timer did not fire? What the heck is going on?
Stargazer
16,568
340
Western WV
Crap! I hit the info button on my remote and my locals are coming in from 129 now. How is this going to affect my timers? Everything is all messed up now. I thought the local news did not look as clear as it did and I guess that would be why, it was not in HD.
Elkview
332
61
Elkview,West Virginia
Charleston WV locals
Huntington/Charleston locals I assume?
If so that is the goofiest setup I've seen for locals
SD on 129
HD on 61.5
SatelliteGuys.US_TheList - Dish Network Charleston, WV
So you could aim the dish that you had at 77W over to 61.5W and get the HD locals back. The SD locals are on there too (the ones not carried in HD)
They are still on 77 (HD) @ 6208 6209 6210 6211 How long will they be here? How do I get them to show up where they were 3 8 11 13?
Mr Tony
3,892
16,982
Mankato, MN
you need to have a dish at 61.5
Those on 77W are just mirrors to get you to upgrade to a EA dish. PM one of the DIRT (Dish internet response team) folks. On main forum page their names are in RED. I'll also let them know about this. It should be a free install since they are moving channels around
MaryB@SlingTV
1,251
14
Colorado
Hi, If you would like to Pm me your account information, I can get you set-up ASAP to get the dish corrected at your home. Please just let me know, thank you!
Tampa8
Supporting Founder - I'll stand up and say so
18,305
8,156
Tampa/Eastern Ct
D
12/12/2011 4:01pm - Uplink Activity Report - 32 changes
D
12/14/2011 2:16am - Uplink Activity Report - 1 change
