2/5/2009 2:12am Uplink Activity Report - 92 changes
Pepper
DVR Addict~Mad Scientist
8,191
1,060
Satsuma, AL
Nice, I'm between the green and yellow lines for the Atlanta spotbeam so maybe I could "move" there if I want. Looks like it's time to connect 129 again and check some signal strengths.
TheKrell
A mighty and noble race originating on Altair IV.
38,838
46,539
Fairfax, VA
20 HD Channels on TP17 am I understanding this correctly? I thought the max you could get on one TP was 7-8 HD channels.
We're loosly speaking as though transponder 17 frequencies were the transponder itself. This is not strictly speaking accurate. For spotbeam transponders, there are actually separate physical transponders for each spot, even though the frequencies they use (and reuse over and over) are the same.
digiblur
14,190
4
Louisiana
I think you should be ok. I was able to lock...barely enough... to read the channel numbers with TSReader on the Atlanta, GA spotbeam. And that's with a Dish300 pointed at 129. The power might be high right now since they don't have the other spots turned on too. Time will only tell.
I'll work on matching some more of the spotbeams to the 129 locals. But it is purely guess work at this point.
digiblur
14,190
4
Louisiana
No...He's counting the mirrors too. There are not that many HD channels on that one transponder.
RandallA
10,556
68
San Francisco Bay Area
374 SMITH MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
385 MGM MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
394 WFN MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
9437 TRV (215) MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
9438 TWC (214) MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
9439 CNBC (208) MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
9479 ACMAX (313) MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Available
4827 TMP57 MPEG4 HD 129?W 17 8PSK (2/3) ConUS beam Not Available
TP 17 has 8 channels, the rest are mirrors like Digi said.
Edit: Added TMP57, thanks JohnH
digiblur
14,190
4
Louisiana
And technically I wouldn't count TMP57 as it is running at 0.5 megabits.
bigjotto316
80
I am looking at a possible "move" from Erie PA, to Columbus Oh..If I see 129W TP 04 that means that I will be able to get the locals from columbus?
MisterLas
263
Flemington, WV
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
"Moved" to Atlanta more than a year ago... now the big 4 are gone! Now all I get is the attached image. Anyone got a quicklink to a site where it can show my location with possible spotbeamed HD locals? I've seen some pics with a google maps/earth image with little drawn circles showing spotbeams, but I can't find the threads now... Anyone got a clue as to what I am talking about? Or am I completely mistaken? Zip is 26347. Thx.
And once again.... NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!:river:river
JohnH
Godfather of the Uplink Reports
Oct 5, 2003
3,013
Kansas City, Missouri
I think its 16x7.
Just to point out it is more than 7. When the new CI HD launched, it made the content in excess of 7 HDs on the Tps where it went. Some will claim that number 8 is a limited bandwidth thingy and in some cases that would be correct at least for now.
61,5
387 CI MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
406 SETA MPEG2 SD 8PSK 61.5?W 21 8PSK (2/3) ConUS beam Available
578 BRDGS MPEG2 SD 8PSK 61.5?W 21 8PSK (2/3) ConUS beam Available
9446 WGN (239) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Chicago, IL Available
9457 GREEN (194) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
9495 CBS C (152) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
9496 SEDGE (352) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
9498 STRZW (351) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
9505 ENCOR (340) MPEG4 HD 61.5?W 21 8PSK (2/3) ConUS beam Available
129
387 CI MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
4820 TMP50 MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Not Available
9446 WGN (239) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Chicago, IL Available
9457 GREEN (194) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
9495 CBS C (152) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
9496 SEDGE (352) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
9498 STRZW (351) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
9505 ENCOR (340) MPEG4 HD 129?W 20 8PSK (2/3) ConUS beam Available
On Tps where the TMPxx channels are, the TMPxx makes number 8 and they have reportedly tested some of those with video.
JohnH
Oct 5, 2003
3,013
Have you tried Pittsburgh?
digiblur
14,190
4
Louisiana
The only locals that have been spotbeamed are in this report. So not many have fired up yet. You are just going to have to wait this one out and see what fires up for your area.
MisterLas
263
Flemington, WV
No I haven't tried Pitt yet because I wasn't sure how to find out what they have and which spotbeam it is on.
Any clue when all of them will spotbeamed?
kenny9966
352
46
Stillwater Oklahoma
36861 - EPG [EPG] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 21 ConUS beam
sorry if this is a lil off topic but does this mean transponder 21 on ciel 2 is the home transponder? meaning best transponder to tweak signal with?
JohnH
Oct 5, 2003
3,013
Some would call it the "Home" transponder. That means, it likely will be there when others may come and go. That may make it the best for tweaking, not because it has the best signal for tweeking. Others may prefer an 8PSK HD transponder.
ehren
1,440
Wisconsin
Dish is gonna squeeze 8 channels per transponder now, hell why not 14!!!!!!!
F***!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Similar threads
D
Replies
Views
2K
DigiDish Uplink Report
D
D
Replies
Views
2K
D
D
Replies
Views
2K
D
D
Replies
Views
2K
D
