3/20/2014 5:49am - Uplink Activity Report - 57 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/20/2014 5:49am - 57 changes
Uplink Comparison Range: 03/19/2014 01:01P - 03/20/2014 05:48A
Channel Additions:
315 - MAX-L [MPEG2 SD] added to EchoStar11 110W TP 05 ConUS beam (NA)
315 - MAX-L [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (NA)
409 - PAC12 [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS beam (A)
409 - PAC12 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (A)
592 - ALT12 [MPEG2 SD] added to EchoStar14 119W TP 12 ConUS beam (A) (H)
592 - ALT12 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (A) (H)
593 - ALT12 [MPEG2 SD] added to EchoStar14 119W TP 12 ConUS beam (A) (H)
593 - ALT12 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (A) (H)
594 - ALT12 [MPEG2 SD] added to EchoStar11 110W TP 24 ConUS beam (A) (H)
594 - ALT12 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (A) (H)
595 - ALT12 [MPEG2 SD] added to EchoStar11 110W TP 24 ConUS beam (A) (H)
595 - ALT12 [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (A) (H)
680 - DUNYA [MPEG2 SD] added to Anik F3 118.7W TP 06 ConUS beam (A) (H)
4084 - AAC [MPEG4 SD] added to Anik F3 118.7W TP 13 ConUS beam (NA)
5409(409) - PAC12 [MPEG4 HD] added to Ciel-2 129W TP 27 ConUS beam (A)
5409(409) - PAC12 [MPEG4 HD] added to Nimiq5 72.7W TP 01 ConUS beam (A)
Channel Removals:
621 - KOREA (NA) [182] removed from EchoStar14 119W TP 18 ConUS beam
621 - KOREA (NA) [182] removed from Nimiq5 72.7W TP 05 ConUS beam
680 - TVONE (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 03 ConUS beam (TV One Global (Urdu))
5453 - ALT12 (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 12 ConUS beam
5453 - ALT12 (A) (H) [MPEG4 SD] removed from Nimiq5 72.7W TP 29 ConUS beam
5455 - ALT12 (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 12 ConUS beam
5455 - ALT12 (A) (H) [MPEG4 SD] removed from Nimiq5 72.7W TP 29 ConUS beam
5457 - ALT12 (A) (H) [MPEG2 SD] removed from EchoStar11 110W TP 24 ConUS beam
5457 - ALT12 (A) (H) [MPEG4 SD] removed from Nimiq5 72.7W TP 29 ConUS beam
5459 - ALT12 (A) (H) [MPEG2 SD] removed from EchoStar11 110W TP 24 ConUS beam
5459 - ALT12 (A) (H) [MPEG4 SD] removed from Nimiq5 72.7W TP 29 ConUS beam
9535 - PAC12 (A) [MPEG4 HD] removed from Ciel-2 129W TP 27 ConUS beam
9535 - PAC12 (A) [MPEG4 HD] removed from Echostar16 61.5W TP 10 Conus beam
9981 - ARANG (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 17 ConUS beam (Arirang TV (Korean))
9982 - BTN (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 17 ConUS beam (Buddhist Television Network (Korea))
9983 - JSTV (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 17 ConUS beam (Jesus Satellite Ministry (Korean))
36849 - DNL1 (A) [143] removed from EchoStar14 119W TP 19 ConUS beam
Channel Package Flag Changes:
5265(49) - WTOKD [MPEG4 HD] - Ciel-2 129W TP 06 Spotbeam 43 changed to Available (H) (Mkt:Meridian, MS-Meridian, MS-CW,)
8383(34) - KUVM [MPEG2 SD] - EchoStar14 119W TP 04 Spotbeam B11 changed to Available (H) (Mkt:Houston, TX-Missouri City, TX-AZTECA,)
8383(34) - KUVM [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 16 changed to Available (H) (Mkt:Houston, TX-Missouri City, TX-AZTECA,)
151 - NCAA [MPEG2 SD] - EchoStar14 119W TP 16 ConUS beam changed to Available (FP)
151 - NCAA [MPEG4 SD] - Nimiq5 72.7W TP 21 ConUS beam changed to Available (FP)
413 - PAC12 [MPEG2 SD] - EchoStar14 119W TP 15 ConUS beam changed to hidden from non-subs (A) (H)
413 - PAC12 [MPEG4 SD] - Nimiq5 72.7W TP 29 ConUS beam changed to hidden from non-subs (A) (H)
736 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam removed from free preview (A) (JUS Punjabi )
4951(172) - DISE [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Available (H) (The Disney Channel)
4952(180) - ABCF [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H) (ABC Family)
4953(141) - ESPNU [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Available (H) (ESPN U)
5020(172) - DISE [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Available (H) (The Disney Channel)
5022(180) - ABCF [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H) (ABC Family)
5501(172) - DISE [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Available (H) (The Disney Channel)
5503(180) - ABCF [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (H) (ABC Family)
5582(141) - ESPNU [MPEG4 HD] - EchoStar11 110W TP 13 ConUS beam changed to Available (H) (ESPN U)
Channel Mapdown Changes:
5454 - ALT12 Ciel-2 129W TP 25 ConUS beam mapdown of 592 added (A) (H)
5454 - ALT12 Nimiq5 72.7W TP 08 ConUS beam mapdown of 592 added (A) (H)
5456 - ALT12 EchoStar14 119W TP 07 ConUS beam mapdown of 593 added (A) (H)
5456 - ALT12 Nimiq5 72.7W TP 01 ConUS beam mapdown of 593 added (A) (H)
5458 - ALT12 EchoStar14 119W TP 07 ConUS beam mapdown of 594 added (A) (H)
5458 - ALT12 Nimiq5 72.7W TP 01 ConUS beam mapdown of 594 added (A) (H)
5460 - ALT12 Ciel-2 129W TP 25 ConUS beam mapdown of 595 added (A) (H)
5460 - ALT12 Nimiq5 72.7W TP 08 ConUS beam mapdown of 595 added (A) (H)
Channels in the system: 9254
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
I had to kick the uplink PC. I was running but it had a corrupted file causing the new uplink report from being created.
Fixed! :D
So, Dish is adding Max Latino? Can't SAP just be used on the main channel? Maybe they could add it to DishLatino packages. :) I know HBO Latino sometimes puts in a different program here or there in Spanish that is different from the main feed although a good chunk of the programming is the same as the main HBO feed. Too bad they did not add Max Latino when it was @Max. Also, too bad they did not add MovieMax. However, these two channel changes seem to mirror HBO (HBO Latino and HBO Family). I am guessing even more transferring of the same movies between the two.
ThrillerMax and OuterMax would have also been nice additions or even MoreMax in HD especially to the subs paying $14/month.
Channel 151 shows the networks carrying the games and to hit Select to bring up the Multiview screen. CBS is not on Multiview, even though it lists it on 151. CBSSN is there instead but I don't believe any games will be carried there...
I wish the Spanish stations had english audio on SAP like the English stations do. sometimes HBO Latino has some good movies on when it's different from HBO. and MundoFox has some good movies too. Seems kinda one sided.
i think he was disrespecting Sd not the language.
Yes, I think so, too. I was not being disrespectful as well. However, I just don't understand why waste space on the same channels. From my understanding, Max Latino will just be like Max East with no difference in programming. At least HBO Latino shows some different programming (although little in my opinion from when we had it free or in free preview) from time to time. However, I think HBO should just have a SAP feature for the main channel and make HBO Latino a standalone channel. Like bradfordj posted above, I also wish the Spanish channels had English SAP or at the very least a way to translate in closed caption as some Spanish channels do. Sometimes you can find some good shows or movies on the Spanish channels with English captioning (I think usually CC3--It's been a while since I've done this, but it's possible through the captioning option on the Dish receiver--Some televisions also have a closed caption as well).
D
3/17/2014 12:19pm - Uplink Activity Report - 12 changes
D
3/21/2014 6:32am - Uplink Activity Report - 1 change
