3/29/2016 18:00 - Uplink Report - 38 Changes
Uplink PC
Uplink Report PC
May 31, 2014
707
6
SatelliteGuys.US DishNetwork Uplink Report - 3/29/2016 18:00 - 38 Changes
Uplink Comparison Range: 3/28/2016 07:15 - 3/29/2016 18:00 (PST)
MAP Changed:
4971 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
4971 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
4972 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (24) added (LOCAL)(Mkt: Tulsa,OK)(A)(H)
4972 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (24) added (LOCAL)(Mkt: Tulsa,OK)(A)(H)
4973 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (31) added (LOCAL)(Mkt: Jacksonville,FL)(A)(H)
4973 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (31) added (LOCAL)(Mkt: Jacksonville,FL)(A)(H)
4974 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Orlando,FL)(A)(H)
4974 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Orlando,FL)(A)(H)
4975 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (26) added (LOCAL)(Mkt: Boston,MA)(A)(H)
4975 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (26) added (LOCAL)(Mkt: Boston,MA)(A)(H)
4976 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Memphis,TN)(A)(H)
4976 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Memphis,TN)(A)(H)
4977 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Dayton,OH)(A)(H)
4977 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Dayton,OH)(A)(H)
4978 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Pittsburgh,PA)(A)(H)
4978 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Pittsburgh,PA)(A)(H)
4979 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Atlanta,GA)(A)(H)
4979 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Atlanta,GA)(A)(H)
4980 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Charlotte,NC)(A)(H)
4980 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Charlotte,NC)(A)(H)
5816 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (16) added (LOCAL)(Mkt: Rapid City,SD)(A)(H)
5816 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (16) added (LOCAL)(Mkt: Rapid City,SD)(A)(H)
5817 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Sioux Falls,SD)(A)(H)
5817 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: Sioux Falls,SD)(A)(H)
5818 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Topeka,KS)(A)(H)
5818 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Topeka,KS)(A)(H)
5819 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Wichita,KS)(A)(H)
5819 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Wichita,KS)(A)(H)
5820 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Harrisburg,PA)(A)(H)
5820 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Harrisburg,PA)(A)(H)
5821 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Washington,DC)(A)(H)
5821 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (28) added (LOCAL)(Mkt: Washington,DC)(A)(H)
5822 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Savannah,GA)(A)(H)
5822 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Savannah,GA)(A)(H)
5823 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (24) added (LOCAL)(Mkt: Indianapolis,IN)(A)(H)
5823 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (24) added (LOCAL)(Mkt: Indianapolis,IN)(A)(H)
5824 - DISH [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to LOCAL , changed to Available , map (16) added (LOCAL)(Mkt: Rapid City,SD)(A)(H)
5824 - DISH [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to LOCAL , changed to Available , map (16) added (LOCAL)(Mkt: Rapid City,SD)(A)(H)
Transponder Changes:
Echostar16 61.5W TP 09 Conus (21.500 8PSK 2/3) added.
EchoStar11 110W TP 09 ConUS (21.500 8PSK 2/3) added.
EchoStar11 110W TP 15 ConUS (21.500 8PSK 2/3) added.
Ciel-2 129W TP 27 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 01 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 27 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 20 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 28 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9778
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
I did not know they were in all those markets--------like DC. Actually I see a few cities that do not have Cox stations. There must be something else in play.
Any word of a dispute with NBC(I don't think that), Tegna(also unlikely), Fox, Sinclair, Tribune, Daystar or ION? Several other stations here but they are public, or likely must carry. Like others I get tired of these disputes but not much I can do about them.
Since, as I understand it, these network stations are FCC mandated "must carry" stations, what happens it no agreement can be arrived at and the stations are blacked out for a lengthy period of time?
It would seem that if the FCC mandates network stations are "must carry " stations, they should also set the compensation paid by the re-transmitters.
While I'm at it, since the re-transmitters extend the stations audience and revenue by increasing advertiser penetration, it would make better sense that the stations pay the re-transmitters to carry their signals, but it's backwards.
Your understanding is wrong. The FCC gives the stations the opportunity to label themselves "must carry" but then the stations cannot demand retransmission fees. These stations want fees, so none have taken on the must carry designation.
Reactions: Tampa8 and TheKrell
IN any event I still think that either the DC entry is incorrect or that there is another dispute brewing.
normally the channel number listed is one off of the ACTUAL channel being in dispute (if possible
It says 28 but there is no 27 or 29 PSIP station in DC so its confusing
Its not all markets. Thats why I thought it was Cox when I first glanced at it
Well, two channels are listed for Charlotte, and Cox owns two channels here, WSOC (Ch 9 - ABC) and WAXN (Ch 64 - Ind). I don't think Media General owns anything in Charlotte
Per another thread 5821 is removed. So we will likely never know what it was about.
4/01/2016 12:44 - Uplink Report - 18 Changes
4/01/2016 16:06 - Uplink Report - 3 Changes
