Very nice job Sean. Nice to see formatting used on the forum, it make a long post easier to follow. Have to ask though, what is USB "two point oscar"?
It's been a while since I wrote a summary but I made myself do it. If I didn't have a DVR I wouldn't attempt it. Mine can be found elsewhere (specifically, http://ekb.dbstalk.com/Tech0505.htm) with plenty of bullets
They said the 942 "Outputs 480p, 720p or 1080i, will upconvert 480i." I thought it would also output 480i to TV1.
Also, the 942 can record from all 3 tuners at once.
Larry, the DPP44 solution may have been better than the "unsupported" SW64/SW21 cascade for the questioner's future setup. I cranked the volume WAY up to hear the first part of the answer and it seems he will later need 61.5° on at least 3 tuners. That will make the DPP44 install much cleaner then but doesn't change that he actually could add the SW21(s) to his SW64 now.
If programming on an external HDD can only be played through the receiver it was copied from, what happens if there is a repair swap? Or when there is an MPEG4 swap?
