kbohip said:
My 522 does this with every recording. I have to switch back to the screen showing all of the recordings to see the right program info.
kbohip, you are complaining about something different than the original poster. You are talking about the banner or info window on a recording giving you wrong show info. He's talking about the shows IN HIS DVR LIST having the wrong name (something you say you're not having a problem with). And by the way, we ALL have the problem you describe kbohip, what you describe is a common bug on the 522.
Wishbone what you describe was a very common problem sometime ago but I have not seen it in quite a long time, and I do a LOT LOT LOT of recording and watching with my 522.
The only thing that seems possible is (and this goes to something that goaliebob99 said, SORT OF) is that you are setting up MANUAL TIMERS with at least a 1 minute start buffer.
You see, if you set up timers the standard name based way, like you find a show in the future in the guide or from a search and select on it and set up a single or recurring timer or Dish Pass, you could set as early a start buffer as you want and you won't have naming problems.
You could add a SIXTY MINUTE early start buffer using the above method and the show you selected on will still be named correct in the recording list.
BUT, BUT, BUT, if you set up a manual timer with even a ONE MINUTE early start buffer, you will have a recording with the name of the last show that was on like what you describe. I can't say for sure but maybe this is your problem. Don't do start buffer on the manual timers.
