6/26/2013 3:47pm - Uplink Activity Report - 72 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/26/2013 3:47pm - 72 changes
Uplink Comparison Range: 06/26/2013 03:31P - 06/26/2013 03:46P
Channel Additions:
6374(18) - WKTB [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 43 (Mkt:Atlanta, GA) (NA)
8910(15) - KUPU [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam A27 (Mkt:Honolulu, HI-Waimanalo, HI-IND) (NA)
6690(6) - WRTV [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-ABC) (A) (H)
6692(13) - WTHR [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-NBC) (A) (H)
6693(59) - WXIN [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-FOX) (A) (H)
5190(13) - WLOX [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-ABC) (NA)
5192(6) - WXXV2 [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Gulfport, MS-FOX) (NA)
5193(25) - WXXV [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Gulfport, MS-FOX) (NA)
5194(16) - WMAH [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-PBS) (NA)
6591(14) - WLOX2 [MPEG4 SD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-ABC) (NA)
6401(61) - KZJL [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 49 (Mkt:Houston, TX-Houston, TX-N/A) (NA)
6401(61) - KZJL [MPEG4 HD] added to Echostar16 61.5W TP 25 Spotbeam 16 (Mkt:Houston, TX-Houston, TX-N/A) (NA)
6382(24) - KPNZ [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 18 (Mkt:Salt Lake City, UT-Ogden, UT-N/A) (NA)
5150(3) - WHSV [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Harrisonburg, VA-ABC) (NA)
5151(9) - WSVF2 [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA) (NA)
5152(4) - WRC [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Washington, DC-NBC) (NA)
5153(42) - WSVF [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA) (NA)
5154(51) - WVPT [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Staunton, VA-PBS) (NA)
248 - MAVTV [MPEG4 HD] added to Ciel-2 129W TP 19 ConUS beam (MavTV HD) (A)
248 - MAVTV [MPEG4 HD] added to Nimiq5 72.7W TP 26 ConUS beam (MavTV HD) (A)
249 - CI [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS beam (Crime & Investigation Network) (A)
249 - CI [MPEG4 HD] added to Nimiq5 72.7W TP 24 ConUS beam (Crime & Investigation Network) (A)
279 - CCNEW [MPEG2 SD] added to EchoStar11 110W TP 08 ConUS beam (A)
279 - CCNEW [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (A)
393 - PRST [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS beam (A) (FP)
393 - PRST [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (A) (FP)
9817 - TVINT [MPEG2 SD] added to Anik F3 118.7W TP 15 ConUS beam (NA)
Channel Removals:
6690 - WBND (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-South Bend, IN-ABC)
6692 - WNDU (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-South Bend, IN-NBC)
6693 - WSJV (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-Elkhart, IN-FOX)
713 - WLLOW (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 03 ConUS beam
14188 - KLRT2 (NA) [EPG] removed from EchoStar10 110W TP 18 Spotbeam 15 (OTA EPG:Little Rock, AR)
14976 - WBBJ3 (NA) [EPG] removed from EchoStar10 110W TP 20 Spotbeam 14 (OTA EPG:Jackson, TN)
19007 - VODAP (A) [DATA] removed from EchoStar11 110W TP 16 ConUS beam
19007 - VODAP (A) [DATA] removed from Nimiq5 72.7W TP 21 ConUS beam
Channel Package Flag Changes:
5255(21) - KHBSD [MPEG4 HD] - Ciel-2 129W TP 03 Spotbeam 37 changed to Available (H) (Mkt:Ft. Smith, AR-Fort Smith, AR-CW)
5260(13) - WBKO [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-ABC)
5261(4) - WNKYD [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-N/A)
5262(40) - WNKY [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-NBC)
5263(33) - WBKOD [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-N/A)
5264(48) - WKGB [MPEG4 HD] - Quetzsat1 77W TP 20 ConUS beam changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-PBS)
5265(24) - WKYU [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-PBS)
6427(16) - KUNP [MPEG4 HD] - EchoStar10 110W TP 29 Spotbeam 44 changed to Available (H) (Mkt:Portland, OR-La Grande, OR-UNI)
5190(7) - KVII [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-CBS)
5191(10) - KFDA [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-CBS)
5192(4) - KAMR [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-NBC)
5193(14) - KCIT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-FOX)
5194(2) - KACV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-N/A)
7684(33) - KCPN [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX)
7685(18) - KPTF [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Farwell, TX-N/A)
7686(36) - KTMO [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX)
240 - PRST [MPEG2 SD] - EchoStar14 119W TP 15 ConUS beam removed from free preview (A)
240 - PRST [MPEG4 SD] - Nimiq5 72.7W TP 22 ConUS beam removed from free preview (A)
361 - MAVTV [MPEG4 HD] - Ciel-2 129W TP 19 ConUS beam changed to shown in non-sub's guides (MavTV HD) (A) (H)
361 - MAVTV [MPEG4 HD] - Nimiq5 72.7W TP 26 ConUS beam changed to shown in non-sub's guides (MavTV HD) (A) (H)
368 - CI [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to shown in non-sub's guides (Crime & Investigation Network) (A) (H)
368 - CI [MPEG4 HD] - Nimiq5 72.7W TP 24 ConUS beam changed to shown in non-sub's guides (Crime & Investigation Network) (A) (H)
677 - ARYDI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Ary Digital USA (Urdu))
689 - QTV [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to free preview (A) (ARY Qu'ran TV Urdu (Sunni-Pakistani))
738 - GETPJ [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam removed from free preview (A)
789 - MNRMA [MPEG2 SD] - Anik F3 118.7W TP 08 ConUS beam changed to Available (H)
9590(103) - HOPR [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (FP)
9590(103) - HOPR [MPEG4 HD] - Nimiq5 72.7W TP 13 ConUS beam changed to Available (FP)
9914 - NOWTV [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam removed from free preview (A)
9915 - NOWTV [MPEG4 HD] - Anik F3 118.7W TP 23 ConUS beam removed from free preview (A)
9942 - NOWHR [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam removed from free preview (A)
9943 - NOWBN [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam removed from free preview (A)
Channel Mapdown Changes:
4272 - MAVTV Ciel-2 129W TP 19 ConUS beam mapdown changed from 361 to 248 (MavTV HD) (A) (H)
4272 - MAVTV Nimiq5 72.7W TP 26 ConUS beam mapdown changed from 361 to 248 (MavTV HD) (A) (H)
4287 - CI EchoStar11 110W TP 19 ConUS beam mapdown changed from 368 to 249 (Crime & Investigation Network) (A) (H)
4287 - CI Nimiq5 72.7W TP 24 ConUS beam mapdown changed from 368 to 249 (Crime & Investigation Network) (A) (H)
Transponder Changes:
Unknown TID#1320 21500 8PSK 3/4 added
Channels in the system: 8861
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
Great my bowling green ky locals finally in hd. Only 1 problem , me, and most other dish subs in bowling green are on western arc. We get the SD off 119 why not HD.?
They switched Louisville over to EA a while back. Probably going to do the same for BG. Call in and get your dish changed.
There's plenty others like that, including Hartford Ct. for instance. Reason? One of many is because there is not much room left on the Western Arc to add HD channels. People with older receivers is another. 129 satellite having most of the HD on the WA is another.
If Dish puts your HD locals up on a satellite you can't receive, they should install a dish for you that will work gratis.
Amarillo Texas lit up on 61.5 yesterday, almost everyone out here is on WA, so the rumor is that Dish techs will be busy little bees for a couple of weeks, especially with Lubbock and 2 or 3 other HD locals markets scheduled to light up on 61.5, too.
Amarillo got 5 major local nets in HD, but Lubbock has 8 locals uplinked in HD, I guess Amarillo has no MYTV, CW or Univision stations in HD.
I give up Scott, getting where?
When the new spotbeam satellite (Echostar 16) went into service at 61.5, the mapping between all those spot beams and what's in the data stream (transponder ID), was unknown. Nelson61 (?) has been getting that mapping updated so that TheList! has the great spotbeam ground maps, and not just "unknown TID". There are so many spotbeams, this has been a laborious process. And when new ones are lit up, then Nelson61 (?) adds that to his tables. HEnce, "we're getting there", meaning getting near completion of this job.
Right on. And, Digiblur had a hardware failure that prevented him from updating his program tables after E16 was added to the fleet. So, we are filling in the missing data when an unknown TID appears in the uplink report.
Just wanted to say THX again to you both for all your hard work. It is much appreciated!!
D
6/28/2013 6:32am - Uplink Activity Report - 4 changes
D
7/1/2013 6:32am - Uplink Activity Report - 2 changes
