622 doesn't play well with 211
daysailor
United States
I'm trying to add a 211 to my existing 622 dual tuner HD setup. Antennas are a Dish 500 with DPP and 2nd dish for satellite 129 connected to the DPP. I have separate cables to 622 and 211. After the 211 is setup to see all 3 satellites the 622 no longer connects to 129. Can anyone offer some suggestions to make these two receivers work simultaneously?
how many cables are coming off of your dish into your home?
I have had my switch get "stuck" before (more likely the receiver actually). I would suggest undoing the sat cable from both receivers, doing a switch test on both to clear the matrix then connect one, do a switch test, then connect the other and do a switch test.
