I had a station I was getting at around 65% - It was not coming in too well and would lock up my 622 as well. I think the 622 does not do well with weak signals. I messed with my antenna, and anytime I got a station below 70% I started seeing the same thing.
I then proceeded to remove the offending channel.
My advice is to remove any channel you cannot get at least a 70% signal or you're asking for trouble when someone surfs to that channel.
I experienced the multipath problem too when I was first adjusting my antenna. My local FOX was jumping back and forth from 80 to 0 every couple of seconds. That really locked the 622 up quick. By turning the antenna a bit so it was pointing more in the direction of this station, the problem was solved.
Are any of your other staions on the fringe of reception? Try pointing the antenna at this fringe station, at the expense of the others (as long as you keep them above 70) and see if that helps.
I've been considering aiming a second highly directional antenna at my fringe station, but the fear of getting multipath inteference on the staions I currently receive well is making me rethink it.
