625 TV2...No Sound?
scott99a
11
I have no sound coming from my TV2 output(I hooked up 3 TV's with no sound on each). Video works fine. I noticed that their is a splitter coming in before the seperator. On TV2 their is another splittler. The splitter is the antenna/dish splitter and TV2 comes through the antenna output. Is this o.k. or do I need a different splitter?
Any help much appreciated.
scott99a
Sounds like a defective 625. Audio and video are carried on the same signal. If you have one, you should have the other. Try hooking the 625's TV2 out connector to the TV that you are currently using for TV1 with a short cable. That should eliminate your wiring from being at fault. Can you tell if there is audio on TV2's audio out connectors? If not, then it's definitely the 625.
