7/17/2014 00:06 - Uplink Report - 46 Changes
  • Thread starter Thread starter Uplink PC
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 7/17/2014 00:06 - 46 Changes
Uplink Comparison Range: 7/16/2014 23:59 - 7/17/2014 00:06 (PST)
Channel Additions:
5198(16) - WGGS [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 56 (Mkt: Greenville,SC (SC-IND))(A)(H)
5227(26) - KXXVD [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 66 (Mkt: Waco,TX (TX-TeleMundo))(A)(H)
5227(26) - KXXVD [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 41 (Mkt: Waco,TX (TX-TeleMundo))(A)(H)
5260(3) - KATC [MPEG4 HD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA - ABC))(A)(H)
5261(10) - KLFY [MPEG4 HD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA - CBS))(A)(H)
5262(33) - WVLA [MPEG4 HD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA - NBC))(A)(H)
5263(15) - KADN [MPEG4 HD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA - FOX))(A)(H)
5264(24) - KLPB [MPEG4 HD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA-PBS))(A)(H)
6355(45) - KSTC [MPEG4 HD] added to Echostar16 61.5W TP 21 Spotbeam 60 (Mkt: Minneapolis,MN (MN-IND))(A)(H)
8489(50) - KLWB [MPEG4 SD] added to Echostar16 61.5W TP 28 Spotbeam 40 (Mkt: Lafayette,LA (LA-IND))(NA)(H)
9789 - TRSPO [MPEG2 SD] added to Anik F3 118.7W TP 14 ConUS (TRSPO)(NA)(H)
Channel Removals:
8192(16) - WGGS [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 18 Spotbeam 56 (Mkt: Greenville,SC (SC-IND))
8577(45) - KSTC [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 19 Spotbeam 60 (Mkt: Minneapolis,MN (MN-IND))
8993(26) - KXXVD [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 18 Spotbeam 66 (Mkt: Waco,TX (TX-TeleMundo))
MAP Changed:
6355(41) - KPXM [MPEG4 HD] Ciel-2 129W TP 15 Spotbeam 14 renamed to KSTC , map changed to (45) (Mkt: Minneapolis,MN (MN-IND))(A)(H)
Channel Moves:
658 - BBCAR [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (BBC Arabic)(A)(H)
696 - STAR+ [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (Star Plus Hindi (Indian))(A)(H)
698 - LIFOK [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (LIFOK)(A)(H)
742 - 9XTAS [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (9XTAS)(NA)(H)
779 - ZEEMR [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (ZEEMR)(A)(H)
792 - ATN [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (ATN Bangla Bangla (Bangladesh))(A)(H)
5150(36) - WTVQ [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY - ABC))(A)(H)
5150(9) - WTVC [MPEG4 HD] Echostar16 61.5W TP 21 Spotbeam 59 moved to Echostar16 61.5W TP 24 Spotbeam 09 (Mkt: Chattanooga,TN (TN - ABC))(A)(H)
5151(27) - WKYT [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY - CBS))(A)(H)
5151(12) - WDEF [MPEG4 HD] Echostar16 61.5W TP 21 Spotbeam 59 moved to Echostar16 61.5W TP 24 Spotbeam 09 (Mkt: Chattanooga,TN (TN - CBS))(A)(H)
5152(3) - WRCB [MPEG4 HD] Echostar16 61.5W TP 21 Spotbeam 59 moved to Echostar16 61.5W TP 24 Spotbeam 09 (Mkt: Chattanooga,TN (TN - NBC))(A)(H)
5152(18) - WLEX [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY - NBC))(A)(H)
5153(56) - WDKY [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY - FOX))(A)(H)
5153(61) - WDSI [MPEG4 HD] Echostar16 61.5W TP 21 Spotbeam 59 moved to Echostar16 61.5W TP 24 Spotbeam 09 (Mkt: Chattanooga,TN (TN - FOX))(A)(H)
5154(53) - WFLI [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 09 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Chattanooga,TN (TN-CW))(A)(H)
5155(46) - WKLE [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY-PBS))(A)(H)
5155(45) - WTCI [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 09 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Chattanooga,TN (TN-PBS))(A)(H)
5156(67) - WUPX [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY-ION))(A)(H)
5195(15) - WHDF [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 09 moved to Echostar16 61.5W TP 32 Spotbeam 09 (Mkt: Huntsville,AL (AL-CW))(A)(H)
5280(16) - WGXAD [MPEG4 HD] Echostar16 61.5W TP 28 Spotbeam 36 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Macon,GA (GA - ABC))(A)(H)
5281(13) - WMAZ [MPEG4 HD] Echostar16 61.5W TP 28 Spotbeam 36 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Macon,GA (GA - CBS))(A)(H)
5282(41) - WMGT [MPEG4 HD] Echostar16 61.5W TP 28 Spotbeam 36 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Macon,GA (GA - NBC))(A)(H)
5283(24) - WGXA [MPEG4 HD] Echostar16 61.5W TP 28 Spotbeam 36 moved to Echostar16 61.5W TP 21 Spotbeam 59 (Mkt: Macon,GA (GA - FOX))(A)(H)
5285(58) - WPGA [MPEG4 HD] Echostar16 61.5W TP 21 Spotbeam 59 moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Macon,GA (GA-IND))(A)(H)
6809 - UP4 [1] Anik F3 118.7W TP 14 ConUS moved to Anik F3 118.7W TP 17 ConUS (UP4)(NA)(H)
9209(28) - WKYT2 [MPEG4 SD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY-CW))(A)(H)
9212(65) - WLJC [MPEG4 SD] Echostar16 61.5W TP 05 Conus moved to Echostar16 61.5W TP 31 Spotbeam 07 (Mkt: Lexington,KY (KY-Telemundo))(A)(H)
9798 - TVBP [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (TVBP)(A)(H)
9986 - TVBE [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (TVBE)(A)(H)
9987 - TVB2 [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (TVB2)(A)(H)
9988 - TVB1 [MPEG2 SD] Anik F3 118.7W TP 17 ConUS moved to Anik F3 118.7W TP 14 ConUS (TVB1)(A)(H)
Transponder Changes:
Echostar16 61.5W TP 21 Spotbeam 60 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 28 Spotbeam 40 (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 32 Spotbeam 09 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 31 Spotbeam 07 (21.500 8PSK 3/4) added.
Ciel-2 129W TP 05 Spotbeam 41 (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 02 Conus (21.500 8PSK 2/3) changed to Echostar16 61.5W TP 02 Conus (20.000 QPSK 7/8)
Echostar16 61.5W TP 12 Conus (21.500 8PSK 2/3) changed to Echostar16 61.5W TP 12 Conus (20.000 QPSK 7/8)
Echostar16 61.5W TP 17 Conus (21.500 8PSK 2/3) changed to Echostar16 61.5W TP 17 Conus (20.000 QPSK 7/8)
Echostar16 61.5W TP 05 Conus (21.500 8PSK 2/3) removed.
Echostar16 61.5W TP 19 Spotbeam 60 (21.500 8PSK 3/4) removed.
Channels in the system: 9453
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
7/16/2014 05:14 - Uplink Report - 2 Changes
7/17/2014 00:55 - Uplink Report - 2 Changes
