722 Install ?
Gentleman
PIT MEMBER
392
9
New Orleans
I am in the process of installing a 722 to replace a 301 and the 722 does not have the channel 3/4 modulator setup and I have a question regarding the home distribution set up, I want to use the 722 in single mode and have a coax cable run to a tv in another room and watch whatever is on the main tv, there is no cable involved, just the coax from the 722, and I am confused with the modulator setup, would I select tv 1 out / air/ and a channel number and thats all to it, I don't quite understand the modulator screen that shows tv1 out and tv2 out
Bob
hook it up to TV2 out when you switch to single mode what ever you watching on TV1 it will be on TV2 as well. you just have to set the modulator to cable or air mode to match the TV setting
Note you cannot select in the 2-13 range but you can/must have TV-1 and TV-2 on different frequencies by 2 chans. This allows using the dual mode with independent pictures. Just do not then put porn on TV-1 and feed it to the kiddies :). In single mode both will have the one picture and you can use PIP on either set.
-Ken
Help with Dish Rebate..8 months still nothing
Equipment return
