722 setup question
MikeInAlaska
189
4
Wasilla, AK
Hello, I added a 722 over at my Dads house tonight, (and hooked him up to a 2nd orbital location) and overall everything went great. He is HD finally.
However...
Remote #1 doesnt work... the infrared one, is there some trick / registration / programming, something? I have to do? The batteries are in, and the lights work on the remote when you attempt to use it.
To test the 722, I switched remote #2 to infrared and it works fine like that, so I know the 722 is speaking infrared just fine. So it seems remote #1 might have a problem? Unless there is some step I did not perform?
Mike in Wasilla
Hit menu twice to go to the info screen and check Primary Remote Address (1-16)
Remote1
Press and Hold SAT Mode button till lights flash
Press 1 (Or whatever the Primary Remote Address is)
Press #
If you want to change Primary Remote Address
Remote1
Press and Hold SAT Mode button till it lights flash
Press (any number 1 to 16)
Press #
Press record
If your dad's TV is LCD, turn off any back-lighting controls. They interfere with the Dish IR remote.
