811& 211 DP34 checkswitch problems
welshboy
10
Nebraska
I disconnected my 811 and on reconnection did a check switch. Only recognized 119 (not 110 & 105). Substituted 211 no problem. Put 211 back in original location and did a checkswitch. Now it has the same problem! Units are about 70' & 50' from switch( with a inline terminal block). Problem solved by moving both units to within 3' of the DP34 and doing checkswitch there. On putting units back in original locations they worked fine. Appears checkswitch cannot drive into long lines with 811 or 211, but once set up actual satellite signal works fine. Incidentally, my 311 will set up on the long lines no problem
50' and 70' are not long runs of cable from the receiver to switch. That's pretty standard, and I would not worry unless there is more that 200 feet total between receivers and the dish. I would be more concerned as to wether that inline coupler (ground block or barrel connection?) is rated for 2 ghz.
Thanks for the feedback. There is actually a ground block and a barrel connector in each line. I have ordered 3GHz ground blocks and will remove the barrel connectors and change out the standard RG6 coax to 3Ghz sweeped RG6.
Programming question
crazy problem with my new 811 HD box....not getting TNTHD or HBOHD?!?!
