921 Optical Out & Non-DD Q?
Mark_AR
1,448
North Arkansas
I just switched out my ANALOG L-R audio outputs to an optical TOS-Link cable on the back of the 921.
I am impressed with the difference optical makes, BUT....
I switched to any one of a number of AUDIO ONLY channels - NO SOUND OUTPUT
I switched to several other channels that didn't have dolby digital(DD) in the Info screen - NO SOUND OUTPUT
I switched back to any channel that had DD and the sound came back. BTW, The Matrix kix serious ass in DD & optical!
So is it me, or is there a problem with the optical out on Non-DD programs?
Is this normal?
How do I work around this without going back to ANALOG L-R?
Do I have to connect BOTH?
The sacrifices we make to be on the BLEEDING edge....
Menu-4-4. Help.
When you're done kicking yourself around the room (or kicking me if I'm wrong :D), remember that not all Dolby 5.1 from any source (sat, DVD, whatever) will be better than analog stereo - audio editors get drunk and lazy a lot more often than they should. If the 5.1 sounds bad, try playing with your stereo's virtual or simulated settings - you may be pleasantly surprised.
SimpleSimon said:
Menu-4-4. Help.
Well that was enough to do it. I had it set for DD only.
As soon as I switched to to DD&PCM the optical out worked on all channels.
I also hooked up the ANALOG L-R to another input so I could hear side-by-side comparison.
In DD broadcasts, the optical kicks. There is a lot more sound seperation between channels and the highs seem crisper.
In non-DD broadcasts, I can't distinguish the difference either way.
As for experimenting with receiver setting, I have a few favorite modes. My receiver auto selects the optimal settings most times and does a fairly good job at it.
Thanks for the 411 or 4-4 as it were. ;)
