942 issues with check switch
Claude Greiner
Claude Greiner
Thread Starter
13,225
3,776
Detroit - The Paris of the Midwest
Anyone else having issues with your 942.
I got one connected to 119/119/129 with a DP44 Plus Switch and it can see the satellites, everything is good but it cannot verify the reception.
SouthRider
SouthRider
SatelliteGuys Guru
Oct 12, 2005
131
9
Covington, La
I had similar issues a few months back.
I kept randomly losing my locals.
In my case it turned out to be that there was no power inserter installed to power the DPP44. Once it was installed the problem went away.
Van
Van
9,326
10
Virginia Beach
Claude does the receiver have the latest software,
have you tried replacing the seperator if your using one,
have you swapped the lines on the switch,
are other receivers working ok on the switch including any other dual tuner,
does it verify 119/110/129 on the switch test,
what coax is being used and is it rated,
are there wall plates and are they rated,
are you sure there are no splitters in the line ( I have seen a splitter allow a checkswitch but not allow verification afterwards )
I had this issue but not on a 942, unfortunately I cant remember what solved it.
Claude Greiner
Claude Greiner
Thread Starter
13,225
3,776
Everthing is hooked up correctly, the only thing I think it can be is that I got 129/110/119 running into my DP44 Plus switch in that order.
Swapped the receiver out with a 622 on the same line but different seperator and it works fine!
Van
Van
9,326
10
Virginia Beach
seperator
Even in that order it should still recognize and lock, double check the connections from one end to the other, I remember the issue now and it came down to a single braid strand that killed the system the same way.
Similar threads
S
Replies
Views
197
HipKat
HipKat
P
Replies
5
Views
511
HipKat
HipKat
P
Replies
7
Views
681
HopperGenie
HopperGenie
L
Replies
4
Views
364
TheKrell
TheKrell
