942 TV2 out connection using diplexers
  • WELCOME TO THE NEW SERVER!
rainier
Hi
Can I combine 3 signals in a single cable using diplexers?
I would like to use TV2 out on my 942 for the second TV in another bed room. To do this, I would like to use the diplexers instead of running a separate cable. I already have a diplexer to combine SAT signal and HD OTA signal into a single cable. On the 942 end, I have a diplexer to split the SAT and ANT and then on the SAT side, I have another splitter to split the SAT signal to SAT1 and SAT2 inputs in the back of 942 receiver. My question is where do I insert new diplexer to back feed video signal to another room. Do I insert it before I split the SAT and ANT signals? Or, insert it after the diplexer on the SAT side? On the SAT dish side, I have a diplexer to combine SAT and ANT signals.
I appreciate your help on this...
That's NOT a splitter, it's a DPP Separator. Different beast.
In short, you do NOT do what you want to do - it's gonna screw up your OTA signal.
If you insist on trying, you do NOT repeat NOT use any more diplexers. You would use splitters.
